Moved to car audio, where it belongs.
This sin't the forum for sucha request, actually. We put full-blown computers in our rides.
You'd be better off checking at a forum devoted to car audio .
Good luck.
Hi,
This question is related to playing MP3s through ICE but it's not a "home brew" solution. Hopefully someone can help me out though and hopefully I've posted this in the correct forum.![]()
I want to get a head unit with USB on the front panel, with the idea that I can plug my Samsung YPZ5 MP3 player in to it, via USB of course, and play MP3s. The Samsung YPZ5 has been firmware upgraded so it now appears as a USB mass storage device. For example, I can now mount it under Linux and drag files on/off like a normal flash drive.
I assume most (if not all?) head untis with USB work in this way? As long as the device you're plugging in is a USB mass storage device and doesn't have some obscure file system, the head unit can read the device and play the MP3s?
Does anyone have any recommendations for such a head unit?
Many thanks in advance for any help and advice offered.
Good luck.
Hit carsound.com's forum, I'm sure we can help you out over there. You may also want to check elitecaraudio.com's forum as well.
Go into a car audio store and try it on the demo decks.
Thanks for the replies. I'll post a carsound.com.
I did go to a car audio store, when I was passing one the other day but they didn't have a clue. When I went to try some of the display units, I couldn't plug my USB cable in because the security cabinet they'd put around them didn't give enough room... they didn't get a sale that day ;-)
Cheers!
most of the new usb units will support mass storage device.
do you have cartoys or bestbuy there?
i have been going around my store with my blackberry phone and pluggin it in the units to see if it plays and most of tem do.
