Results 1 to 3 of 3
Thread: rca turn on
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    rca turn on
    Hey, not sure where this would go exactly... but i was thinking, if you have a stereo that puts out lets say 5v to the rca's... then couldn't you have that go through a relay, which would connect the 12v to the remote turn on on an amp...?
    esentially have your amp turn on whenever sound is applied... without having to run a remote turn on, and have it go off when the music stops...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Actaully some amps do this already, JL slash series for example. But it more when you are using high level inputs (Speaker level), not low level (RCA)
    The problem with using you audio signal is that is an AC source and not a DC source. If it were DC it woudl be easy, otherwise you must design a special circuit.
    Jul 2001
    The JL dot series did it too.
  1. Help with Epia M10K RCA Video
    By wizz in forum General Hardware Discussion
    Last Post: 05-23-2007, 02:39 PM
  2. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  3. Replies: 1
    Last Post: 10-14-2005, 06:11 AM
  4. minimum distance between power & rca wires
    By michaelrj9 in forum Car Audio
    Last Post: 08-30-2005, 02:02 PM
  5. Turn on hiss/not thump. Weird. Dont flame me, read.
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 09-01-2004, 03:25 AM
