Results 1 to 10 of 12
Thread: Whats wrong
    Aug 2005
    salina, kansas
    Question Whats wrong
    Hey I have a pioneer DEH3500 head unit and a Rockford p5002 amp and two MTX road thunders and it all works fine except for the dimming lights. I recently bought a Lightning audio 1/2 farad cap, charged it, the battery is at 12.69 volts and i chargerd the cap to 12.58 volts. Now that it is installed correctly, sometimes the amp turns on and works like it should and others it doesnt turn on at all or turns on then off. The protect light does not turn on, on the amp, and i do have it wired right. So whats wrong does anyone have any wisdom for me? Help me out if you can, thanks.
    Mar 2006
    Colorado, but Canadian!
    Does when it turn on and off to when it stays off have any correlation to when your car is running or how charged your battery is?
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    salina, kansas
    Question whats wrong
    Hey it stays off when it turns off and the battery does keep its charge and its only around one year old, but i know it could be just a bad battery, but if you know whats wrong just reply.
    Jun 2005
    Washington
    my friend had a simalar problem and it was the amps ground
    Apr 2006
    Ground
    Quote Originally Posted by compnut21 View Post
    With that amp it's probably 90% likely to be the ground. I used to see that problem alot installing stereos. The best practice is to ground the amp and the cap together and tightly using the bolts that hold down your car seats. If you can wiggle the cable at all you have a ground problem and it's guaranteed to give you spotty performance.
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    What's wrong is that this was posted in Suggestions/Comments.....
    Peace,
    Rafster
    Elsewhere
    Quote Originally Posted by Rafster View Post
    Moved to Car Audio... Just for Rafster.
    How about the Wiki?
    Aug 2005
    salina, kansas
    Question What now
    Now that i have cleaned the ground on my chassis it work fine now thanks. Now the only issue is that there is always current being drawn from my battery, so now what do i do?
    Apr 2006
    What do you mean current always being drawn from your battery? If you have the amp turn on connected to your "acc" line or your power supply then the amps should turn off with your car and there should be no pull on the battery.
    Aug 2005
    salina, kansas
    Hey the grounds cant get much better. Do the cap and the amp need to be grounded seperatly or together? I have noticed that when i turn the outputs off at the head unit it will turn on and then i turn on the outputs and it will work just fine. So what is up?
  1. booting from CF card slower than HDD, disappointed. what's wrong?
    By mattress in forum General Hardware Discussion
    Last Post: 08-25-2006, 02:11 PM
  2. Songs playing in wrong order
    By supergeek in forum Media Engine
    Last Post: 05-16-2006, 10:19 AM
  3. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum Power Supplies
    Last Post: 09-06-2004, 05:08 PM
  4. Ok here's another, "What's wrong with this picture"
    By CrazyLittle in forum Off Topic
    Last Post: 04-25-2002, 12:11 PM
  5. Something wrong, help need! : making -8V and 5V PS,
    By helloman in forum General Hardware Discussion
    Last Post: 04-27-2001, 04:51 PM
