Have you tried a stiffening capacitor to smooth out the voltage to the amp. I don't know if it would work, maybe caraudioguru can chime in.
ok so i have the clicking coming from the amp, so i moved the ground point all over the place trying to sort this. But still no luck, so currently i have removed most of the rear of my car (dont ask) run a lead straight from the amp to the negative point on the battery, still clicks. I i disconnected the Alternator and started the car again and the clicking stopped. Should a try something like this -
http://caraudiosecurity.com/shop/pro...s_id/2917.html
could this solve my problem, or is it the alternator itself?
Cheerz
