bridging means using 2 channels from the amp as one bridged output.... this can be done in a Y which would be parallel, or it can be done in a U, which is called in series.. the difference is in the y configuration, the impedance of the 2 subs would wind up with a total of half, so 2 X 4 ohms in this config will give a total of 2 ohms... in series the impedance adds up instead, so the same 2 subs will look like 8 ohms to the amp...
as far as volume, for the most part, your only concern is what the final airspace is... there can be issues of standing waves & there are thought to be "the perfect box" design, but for entry level stuff like your dealing with, the volume is really your only concern.... how you get this volume is dependant on the shape & size of the box itself.... one good trick if your working with odd shapes is to get a 1 cubic foot box & a bunch of styrofoam peanuts, then you can estimate the end results by seeing how many times you can load a 1 cubic foot box of peanuts into the box you built to see the end result... IE: if you can fit 2.5 boxes of peanuts in the sub box, 2.5 cubic ft... this is not the most acurate, as the peanuts will pack differently each time there shifted from one enclosure to the next, but it's close enough most times... to do this really acurate it can be done with water... but I doubt your needing to go that extreme....
LinkBack URL
About LinkBacks
I like bigger than 6 1/2's too....
