Results 1 to 10 of 14
Thread: Help wiring tweeters to amp
    Nov 2006
    I'm working on re-wiring the stock speakers in my car straight to my 6 channel amp (I'm not using a head unit, just my carpc). Front and rear left and right are pretty self explanatory, no problems there, but I don't understand where I should wire the tweeters to.
    Sorry if that sounds confusing, here's an example. My front right speaker is wired to front right on my amp. Can I also wire the front right tweeter to the same spot?
    Nov 2005
    CT
    Are you wire components using a passive crossover or are doing an active setup?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you need a passive x-over otherwise you'll be dropping the load to 2 ohms or raising it to 8 and getting the full signal to the tweeter and blowing that speaker. you may want to look into replacing the at least the front speakers to make things easier on you.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Nov 2006
    So if I get new front speakers with built in tweeters I won't have to worry about the crossover? If that's the case it does sound easier....Any suggestions for speakers?
    thanks for the quick replies by the way
    Dec 2004
    Los Angeles Ca
    you could get the ones with built in tweeters, they are called coaxial speakers. or you could by component speakers that have seperate tweeters and a seperate x-over. basically you just wire up the tweeter and the mid range speaker to the x-over's outputs and then the x-over's input to the amp. and you'd be good to go.
    as far as suggestions, go to a local car audio shop and find something that sounds good to you.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2006
    Ok, looking online coaxial speakers appear to be significantly cheaper than components. Are components that much better, or should I save my cash?
    Dec 2004
    Los Angeles Ca
    components are much better. the use high quality x-over components at a steeper slope. they give you more mounting options and usually can handle more power.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2006
    Cool. Thanks for all your help, I'll see if I can pick up a set this weekend.
    Now onto the next problem on my list...
    Feb 2004
    San Francisco
    Just because components are better, that does not mean coaxials are bad. YOu just have to decide how much you are wiling to pay, and how much time you are willing to put in, that will tell you what to get. I have heard good things about the infinity coaxials. I don't have them, so i can't say for sure though.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    JC-S60 has some infinity coaxials, and even without any form of box around it, they still sound pretty desent, even put out a enough low-mids to make it bearable to listen to....
    one of the main reasons components are used over coaxials/triaxials, is the ease of seperate woofer- and tweeterplacement.
    In my opinion the speakers themselves aren't any better in component-sets, but yes, the x-over being used will be better, and with seperated tweeters and woofers it's easyer to build up a good soundstage. An other option - only if you don't have the money for a desent component-set - is to buy a coax that sounds good to you, and seperate the tweeter from the woofer*
    *note: you'll need to buy/ build an x-over yourself.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  1. Replies: 67
    Last Post: 10-15-2006, 09:35 PM
  2. Amp Shuts Off
    By ElementXofXMusi in forum Car Audio
    Last Post: 07-18-2006, 08:34 PM
  3. Amp wiring help
    By Fordranger in forum Car Audio
    Last Post: 05-20-2006, 04:55 PM
  4. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  5. Using existing amp wiring for OPUS/Inverter?
    By SwapMeet in forum Power Supplies
    Last Post: 11-12-2004, 04:39 PM
