Results 1 to 10 of 14
Thread: Broken speaker wire
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Unhappy Broken speaker wire
    Ok. So a few weeks ago I started hearing some distortion in my sound system. crackling static noises. Eventually the right front speaker in my 93 Honda accord began to cut out, only working at low volumes or when i hit the door panel just right.
    Fearing I had blown the speaker, I decided to take the door apart and check. This sounds like a simple process, but has become much harder then i expected.
    I have removed every single screw i can see from the door panel, and was able to pop it loose enough to remove the speaker and test it (the speaker is fine). So that narrows the problem down to a broken wire. Replacing the wire would be easy if I could get the door panel entirely off, but the peice of plastic holding the door lock button and door handle refuses to come loose. I've pulled on it as hard as i dare and it doesn't give at all, like theres more screws that aren't visible holding it to the door.
    Can anyone help me with removing the door panel entirely? I suppose i could take it to a mechanic, but i really dont want to pay an hours labor to run a single wire....
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Thanks for the descriptive Thread Title.
    Check on a Honda Forum. Someone here probably has the answer, but someone there DEFINITELY has the answer.
    Sorry, I can't help.
    Michael
    Jul 2003
    Fremont, CA
    Will do. Anything is better then my chiltons at this point. All it says is "remove all the screws and take the door panel off." Google hasn't born much fruit either. I get lots of honda results, lots of accord results, lots of door panel results, and even lots of results for 1993. Nothing about the door panel for a 1993 honda accord though.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Pictures help sometimes. Chances are if the door panel is still binding there are probably screws attached. Just remember the internal door handle should have a screw or two since that is what you use to pull on the door the most.
    Also, running speakre wire through your door boots ina Honda will be an experience in itself. Plan plenty of time and be prepared to get frustrated.
    One more thing...judging by the year of your car, I bet the crackling/intermitant sound is due to corrosion on the terminals of the speaker wire ends that plug into the speaker.
    Good luck.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    You should just take it to an audio shop and tell them to rewire your speakers.....shouldn't cost too much and you know that it will be done the right way (usually).
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    there should be 3 screws... i think
    one in door handle 1 in arm rest and a plastic one near the top closer to the door hinge
    Jul 2003
    Fremont, CA
    Quote Originally Posted by MegaloRESE15" View Post
    I've removed 2 screws from the arm rest, 1 screw from the door handle, and two from the bottom of the door. the enitre panel is loose and can easily be moved around, but it cant be pulled free from the door because the door handle is still in the way.
    This is a picture of what I can't get loose. If there are more screws holding it in place other then the one visible on the pic, they're behind the door panel where I can't see them.
    I'm really hoping that the problem is a couple of wire nuts that were used to connect the speaker to the wiring harness. I suspect if I just replace them with solder joints everything will be fine again, but soldering while laying underneath the wires I'm working on seems like a good way to get molten lead in my eyes... So the door panel has to come off.
    If i have to run a wire through the door boot I think I'm going to buy a hamster and tie a string around him, then push him into the wiring conduit and catch him when he comes out the other side.
    Jan 2006
    The Colony, TX
    well on my 00 accord there are 3 screws total, the rest are snap-offs, you might have to apply a bit of force. cause the last thing honda dealers wat is more screws...but then again u have an older model
    Jul 2001
    Fluffy, push the whole door handle thing toward the front of the car and it should loosen enough so you can pull it off of the panel and disconnect the rod that goes to the latch.
    Sep 2006
    Agree with Shadow. You will have to turn or twist the door handle part a bit (be careful not to twist too much or you might break it) you have pictured so it can slip through the hole in the door panel. Then you can push the whole dorr panel forward or maybe backward until you get it worked through the hole.
    EDIT: I think I might have my cars mixed up. Ignore this post and go with Shadows post below, it sounds correct.
  1. Pseudo-FAQ: What Do I Need For A Carputer?
    By Maheriano in forum General MP3Car Discussion
    Last Post: 07-03-2006, 03:04 PM
  2. lengthening fm transmittor antenna wire
    By hand in forum General Hardware Discussion
    Last Post: 03-24-2005, 11:21 PM
  3. Replies: 16
    Last Post: 07-30-2004, 01:46 PM
  4. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
  5. RCA to Speaker wire?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-16-2004, 03:20 PM
