Results 1 to 7 of 7
Thread: Car amp goes into protection mode
    Apr 2006
    Hi all i was recently jus cruisin down the road with my amp on workin fine, then all of a sudden it shuts off and when i turn it back on the protection light comes on? so i took it all apart and i moved the amplifier i mounted it on the back seat in the boot, i reconnected it all etc, then tried it again still no luck i dont know if mouting it on the back of the seat has an effect on it? because it is screwed into metal? or if the amp is broken or ive blown somethin? my bro tried something he took the earth off from where is was under the seat connected to the chassis of the car and then tried to turn the amp on again, its supposed to not even work cuz there is no earth but it still comes on into protection mode? any help will be much apreciated, thx bobby
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    bad ground (earth)
    unmount the amp, place it on something like carpet. dont bolt it down. Connect to a good ground source with a good thick cable. See what it does.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Jul 2001
    The amp is pulling ground through your RCAs and using your radio's chassis ground.
    Unplug the RCAs and the amp will turn off, I almost guarantee it.
    PS, if the amp did come on your car would probably catch fire since it'd pull 10+ amps over a 24AWG wire.
    Apr 2006
    Quote Originally Posted by Shadow View Post
    Hi thanks for your reply. the thing is the amp used to work fine, then it all of a sudden cut off, but when it did work it used to have an altonator whine on the speakers and the speakers n sub used to pop when it came on also, sometimes i had to keep turning off n on my head unit like 10x b4 the amp would come on, then one day it jus cut off altogether. n thats the stage im at now, one of my rca cables is dodgy, because one has snapped inside so my old man replaced it with some dodgy fix up by puttin a screw in it and pluggin it into the amp lol sounds messed up i know but costs 20 for a new wiring set. i will give your idea a go 2moz at work thx for your help
    Apr 2006
    Shadow you was right about the rca's and yes the amp did turn off, so i re earthed it put the amp to its basic state, with jus the power, remote wire & earth cables connected to the amp. then tried it still no luck the amp goes into protection mode. ive tried 3 different earths and still no luck? then my bro earthed it to the negative on the battery and the amp was workin come on green light then it blew the fuse in the fuse holder near the battery? so i put another fuse in the fuse holder tried it again and it jus went back into protection mode i really have no idea whats goin on with this amp its a pain. any help wud be apreciated thx
    Jul 2001
    Sounds like your amp is dead.
    Apr 2006
    probably is, anyway ive got one more test for it, im goin to try it in my brothers car because he has the same amp as me, and if it dont work its goin back to the shop, and if it does well i dont know :S
  1. small amp for car
    By secretagentman in forum Newbie
    Last Post: 07-06-2006, 12:08 AM
  2. Car amp in a home?
    By JoshG in forum General Hardware Discussion
    Last Post: 04-23-2006, 03:15 PM
  3. WTB: 4 channel car audio amp ...
    By mattress in forum Classified Archive
    Last Post: 06-20-2005, 11:20 PM
  4. noobie needs advice on buying a car amp
    By minghi in forum Car Audio
    Last Post: 03-30-2005, 11:00 AM
  5. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
