+ Reply to Thread
Results 1 to 5 of 5
Thread: How to bridge this amplifier
    Nov 2006
    Hi people I got a two channel amplifier but I couldnīt get the specifications so I donīt know how to bridge it. Iīm sure I can bridge it because it is write in the amp. It has this configuration...
    ......." In the image box at the bottom"........
    Does it mean that I need to connect + from L-CH and + from R-CH to bridge it up? The + from the R-CH is now transforming in a - ? This is really confuseĄ Could someone explain me whatīs going on here...
    Also I know that all of you know what happen...
    I trying to bridge it to mono for a 4 ohmn speaker, the low in impedance from 4 to 2 ohmn in a bridge amp will kill my 4 ohmn speaker or not ?
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Connect + from one side and - from the other. The resistance (ohm load) of your speakers stays at 4 ohms. It's the amp that is now seeing 2 ohms per channel when it's bridged. As long as the speaker can handle the increased power you should be okay.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Replace the "bridged" with your speaker.
    Some amps bridge the channels differently. Some use the + from one channel and the - from the other channel. Others use both + and one essential becomes the -, like your amp.
    Nov 2006
    So what is the real way
    positive from LCH and negative from RCH or
    positive from LCH and positive from RCH and the positive of the RCH will change to negative when bridged...
    Sep 2006
    Quote Originally Posted by Williams16 View Post
    The Positive from the Rch becomes negative. So your second statement is correct according to that diagram. That was on the amp right?
+ Reply to Thread
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 08-26-2011, 09:30 PM
  2. Replies: 15
    Last Post: 02-15-2006, 12:50 AM
  3. Looking for small amplifier
    By Suprapc in forum Car Audio
    Last Post: 10-05-2005, 06:27 AM
  4. Can i use the amplifier cables for car pc?
    By TRONiC in forum Power Supplies
    Last Post: 04-29-2005, 12:41 PM
  5. What I did to to eliminate amplifier turn-on pops
    By lfilomeno in forum Car Audio
    Last Post: 04-11-2005, 08:31 AM
