Results 1 to 6 of 6
Thread: Earphone port to back of HU?
    Dec 2006
    I am pretty new to carputers and I was wondering if I could just run a headphone wire from my carputer to the back inputs of my HU VIA RCA adapter? Is this possible?
    Elsewhere
    The speaker out, nto the headphone jack.
    You may need to boost the signal scrength with a line converter or a pre-amp.
    How about the Wiki?
    Oct 2006
    Short answer : Yes
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    headphones share a common ground between the L and R speakers. your headunit may not like sharing a common ground so you'll have to consider that as a possible obsticle.
    you'd most likely need a mini headphone amp so you'll have seperate volume control. (i'm assuming this if for a passenger and not for the driver...which would be really dumb) you can purchase or build a cheap 'cmoy' amp that will take a the pre-amp level outputs of the headunit and convert it to an amplified headphone output with volume control.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Quote Originally Posted by scott_fx View Post
    Scott, I think you kinda bypassed what the OP was mistakenly asking. He wanted to know if he could plug the output of his computer into his HU. He mistakenly used the phrase 'headphone' in there.
    Dec 2005
    search for the head unit with auxiliary in or hack your head unit and put aux-in yourself if possible.
  1. Laptop USB as audio out to HU USB port?
    By ZJ_JIM_96 in forum Car Audio
    Last Post: 11-15-2006, 11:59 AM
  2. Ipaq's reciever for PC's com port
    By dimpap in forum GPS
    Last Post: 11-15-2006, 04:36 AM
  3. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:47 PM
  4. Replies: 5
    Last Post: 06-30-2004, 02:22 PM
  5. Spliting power on a PS/2 port...
    By Defiler in forum General Hardware Discussion
    Last Post: 02-27-2002, 03:02 PM
