Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 113
Thread: Pioneer CD-UB100 USB-adapter
  1. #11
    Jan 2007
    Hi Guys,
    Ok, the CD-UB100 will work with any P series head units, the level of functionally will vary though.
    All of the older P series units will give basic functions and of the newly announced units only the DEH-P4900IB will give on screen display of the file and folder names, all of the other P series units will give the 'USB F001' display.
    The video should be up by the end of the day, if i can figure out how to get YouTube to work.
    I don’t know much about the US product range as I don’t live there, they are normally tweaks on the European range.
    I'm not going to make comments as to products that have not yet been published but the PDF you guys have seen is a preview so stay tuned for the full brochure...
    Jim, those units with the *, they are the ones in the catalog, it will work with older head units, that’s the good thing about the P bus system. The preview has the basic range for the time being, more advanced units will be along later.
    bbfoto, yep it will work fine but in a compatibility mode.
  2. #12
    Jan 2007
    Hi Guys,
    You may be interested in the user manual, it is on the Pioneer USA site...
    http://www.pioneerelectronics.com/pn...tailsComponent
  3. #13
    Jan 2007
    Quote Originally Posted by Pioneer_Man View Post
    Hi Guys,
    This is a very useful link that you have put up. It answered a lot of my questions about the compatibility issues that i raised.
    Please keep us posted on the video you are putting up on youtube. Thanks PioneerMan
  4. #14
    Jan 2007
    Hi Guys,
    I donít know much about the US product range as I donít live there, they are normally tweaks on the European range.
    Jim, those units with the *, they are the ones in the catalog, it will work with older head units, thatís the good thing about the P bus system. The preview has the basic range for the time being, more advanced units will be along later.
    From one Pioneer Man to another,
    Will this USB unit allow you to play WMA's when connected to the Z2?
    Jan 2007
    Indiana
    Does anyone know why the 15000 file limit?
    I noticed this on the Kenwood units too. This is the main reason I am looking at a full carputer, because I have more than 15000 files.
  6. #16
    Jan 2007
    lunapark: It should work fine but I’m not sure of the level of display you would get, on that unit you may only get the 'USB T001' type of display, I’m going to look into that one when I have the time.
    I would have had some video up sooner but my camera is playing up, maybe in the next 24 hours or so.
    The 15000 file limit is probably due to memory constraints in the IC that drives the system, its a Telechips IC that is probably used by quite a few manufacturers. I have found that when using a HDD with a lot of files causes quite a delay before playback starts, that may be due to the pre-production unit that I have.
  7. #17
    Jan 2007
    lunapark: It should work fine but Iím not sure of the level of display you would get, on that unit you may only get the 'USB T001' type of display, Iím going to look into that one when I have the time.
    I am in the middle of deciding between the two, the shop is waiting on me to make the order for the Z2, drop me a line at [email protected] when you find out.
    mv1
    mv1 is offline
    Feb 2007
    Hi,
    Q. for pioneer men
    Is't USB adapter CD-UB100 can work with model KEH-P7800R???
    tnx
  9. #19
    Feb 2007
    Hope this helps
    I recently installed this. I have a DEH-P860MP hu. The install is a breeze. Just a ground and constant power. The usb that you are using MUST be FAT. I have a 60 gig HDD that I had to re-format into two partitions in order for this to work. One word of advice, Win XP can only format FAT with a size smaller than 32 gig. Anything larger has to be NTFS and this unit does NOT recognize it. Also a word of caution, you CANNOT partition the drive. Example, 60 gig HDD formated 32 gig FAT and 28 NTFS. The unit will not recognize. If you have something small that 32 gig you're fine over that, in order to format you need either a computer running Win 98 SE or get (or find) a program called Partition Magic. You can however format a drive larger into 32 gig FAT and leave the remaining portion unallocated. With most Pioneer units, you CAN get Artist, Track, or Folder name to be displayed. There is a Scroll feature, scan (which give a 10 sec preview of each track), track forward and back. Fast forward and back. It really is a neat unit. It's nice to have all my music in one spot. Let me know if I can help any further with this.
  10. #20
    Jan 2007
    It works with ALL pioneer head units with a P-Bus connection and this is denoted by the P in the model name....
    DEH - CD Head unit
    P - It has a P-Bus connection
    7800 - Model number
    MP - Added functions ( in this case it will play MP3 from CDR and CDRW disks)
    I hope that has cleared some things up.
  1. EnGenius EUB-362 Wireless Wifi USB Adapter Review
    By L-U-R-C-H in forum The Review Palace
    Last Post: 09-10-2007, 10:21 AM
  2. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  3. self powered or bus powered for USB wifi adapter
    By jagsnag in forum Wireless Communications
    Last Post: 07-28-2005, 07:49 PM
  4. 802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet?
    By Bailey in forum Wireless Communications
    Last Post: 01-22-2005, 12:33 PM
  5. USB to ide adapter + Toshiba laptop dvd drive
    By carprowler in forum General Hardware Discussion
    Last Post: 06-25-2004, 12:49 AM
