Results 1 to 5 of 5
Thread: Audio Question Turtle Beach Roadie
    Nov 2005
    Hey i have a few questions im first off new to the whole car PC audio
    I m well knowledged in car audio, but am looking to transfer over
    After reading some reviews im most likely going with the TB Roadie USB
    my questions is.. i understand i just connect this to my USB which i probably will get a PCI card dedicated for USB...
    but the thing i m wondering is how do i hook my amp up to this thing?
    and what voltage are the outputs???
    or what would you suggest i m looking for an all around good 5.1 channel and hopefully 4V or higher... out put... i'm still debating on the amp, because i want to figure out the pc thing before i purchase a 5 channel amp...
    how is sound compared to a cd headunit? i hooked up a laptop to the headunit i have and it was very poor quality... so i understand the USB cards boost the sound but i m looking for clean quality.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    first question...why do you want 5.1 sound? you'll be much better off giving up on that and concentrating on a card that is meant for stereo sound. are you dead set on 5.1? and do you plan on making a dedicated center chan speaker? if not i think we could find you a much better card (sound quality wise) but if you want 5.1 then there are a few options there as well. soooo... tell us more
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Nov 2005
    well sorry i want stereo sound then i was just referring the the amp i would getting... this is my first car pc.. i dont want to spend too much yet...
    what card do you recommend?? then just for stereo! i m looking for clear quality... and my running a full focal interior so on my current setup they are awesome, so thats why i was debating if i should get rid of my headunit or if i can get rid of it but achieve same or bettter sound quality with high volt outputs
    Dec 2004
    Los Angeles Ca
    what's your budget? i'd suggest looking into a pro pci card like em-u (hard to beat this one), m-aduio audiophile 192 and use your amps internal x-overs. I suggest pci because it sounds like you have the available port if you were going to use it for a dedicated usb port for the audio card. i also suggest going used so you can try out some different options.
    look at these:
    http://cgi.ebay.com/E-MU-0404-PCI-Au...QQcmdZViewItem
    http://cgi.ebay.com/M-Audio-Audiophi...QQcmdZViewItem
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2005
    thanks. i looked into those cards, one question how would i run my sub off of those ??
    so i m guessing i have to use a little connector that goes to RCA cables a y-split thing.....
    how would the sound be? sorry for all these questions i m slowly grasping this new wave of technology.. :P
    im looking more towards the m-audio or would u suggest the EM-U
  1. Audigy / Audigy 2 audio question...
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 04-12-2005, 11:04 PM
  2. Audio Wiring question....
    By jusatry in forum General Hardware Discussion
    Last Post: 01-02-2004, 03:08 PM
  3. audio interface question
    By evank in forum General Hardware Discussion
    Last Post: 06-06-2002, 08:34 AM
  4. Question about audio system for CRV99
    By blahblah in forum General Hardware Discussion
    Last Post: 11-13-2001, 04:56 PM
  5. audio cable question
    By daver in forum General Hardware Discussion
    Last Post: 10-04-2001, 02:04 PM
