Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Unusual amp shut off problem....please help!
  1. #11
    Newbie TheQuinsta's Avatar
    Feb 2007
    Whangarei, New Zealand
    Quote Originally Posted by durwood View Post
    Check to make sure the impedance of your speakers matchs the impedance of the amp. If you have them wired as a 2 ohm load and the amp only rated for 4 ohms, that will cause the amps to go into protection mode too.
    Alos, like the rest of them said, check to make sure all connections are secure.
    This boys onto it . My guess is that the 6*8 is not a 2 ohm speaker there are not many if any that are ,unless you have them in parallel, most are 4 ohm while house stereo are 8 ohm *(i believe) your amp will be overloading .
    I dont think its a wiring problem or you would more than likly get a interference with your sub amp just a spk prob, but check your conns anyway. RCA's wont shut an amp down they only transfer the audio signal,
  2. #12
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    Quote Originally Posted by lifemalfunction View Post
    First off, is your amp stable for 2ohm stereo? Secondly I would be checking the connections at the crossovers and the speakers, one little short is all it takes.
    they SHOULD be the same size as the power with SOLID connections.
    lol, I know that, I was just making sure the OP had that, could be a reason for his/her troubles...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  3. #13
    Dec 2007
    i have just installed a new stereo in my 87 chevy wit 2 kicker tvt 12s with type s 6x9's and type r 61/2's i have 2 planet audio amps one 2 channel 500 watt for my subs and a 4 channel for my spakers i was playing music setting my amps then the next day when i came home i went in to listen to some music but when i turned up the volume eveyrything shutoff my headunit then came back on but my amps have not come back on since does any 1 know what could be wrong???
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  3. Replies: 25
    Last Post: 08-04-2005, 12:49 PM
  4. power to amp problem
    By djXternal in forum Car Audio
    Last Post: 06-01-2005, 10:39 PM
  5. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
