if you're comparing i'd look into the idq or idmax as well :-)
True, True!!!I did notice one thing about kicker and JL though, JL component speakers definately sound better than Kicker ones... but as far as the subs go as of right now i think Kicker has the upper hand. I would definately like to see if someone can prove me wrong then i will invest in a pair of W7's and have a system that really rocks
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Apples and oranges. You had a 12w6v2 which is totally different from the W7. Are you saying that if 400w is enough to push your 12w6v2 then it's enough to push the w7 just as loud? I don't think that's true. Consider this anology...You take a c5 corvette (350hp) and put it up against a civic (190hp?) then the corvette will be faster. But if you apply only 190hp to the vette I bet the civic will be faster. Point being W7 has more mass and a greater distance to move (xmas on W7 1.15" vs your sub's .65") So it's going to require more power to get the desired output than your 12w6v2.
i dont think he was comparing the w6 to the w7, rather the hatch compared to a sedan
M10k
My Car Pc Install
My Boat Pc worklog
System always under construction
There are other factors involved. W7's are power hungry monsters. The L7 is probably mroe efficient with the power and being that it's cone surface area is greater, it probably moves more air then the W7.
But the W7 will play lower than those L7's and sound nice doing it.![]()
My L7 did make my girlfriend puke, id hate to see what 2 W7s will do!!!
You can't beat the L7s for the price though. Absolutely nothing compares to the output of an L7 for under $200. How much is a W7, like $400?
pics of this L7 w/ a custom fiberglass box i built for a customer. saved lots of trunk space and sounds freaking AWESOME!
i know i know! but we couln't find the same color carpet
amps mounted under teh seat
Is wiring up a Prius any different than a regular car due to the hybrid drive? Just curious.
