Results 21 to 30 of 40
Thread: Alternator size ?
  1. #21
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    Could of sworn I said all of this in my first post, caps and extra batteries are just band aids, if the current draw is greater than the output of the alt, houston, you have a problem. I will agree with IC-C30 that upgrading the big 3 will help, at least to provide stabilization to the voltage and better availablility to power.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  2. #22
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    Current Draw by Power
    RMS(watts) Current Amps
    100 watts - 16 amps
    200 watts - 32 amps
    400 watts - 64 amps
    600 watts - 96 amps
    800 watts - 128 amps
    1000 watts - 160 amps
    1200 watts - 172 amps
    1400 watts - 188 amps
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  3. #23
    Jan 2007
    But how loud is all of that? No one listens to their system at max wattage all the time.. so is 1000 watts only audibly 2x as loud as 100 watts?
  4. #24
    Sep 2006
    Georgia
    Quote Originally Posted by netchris View Post
    Music doesnt play at max wattage. Only a true sine wave will push out that kind of power. Music can be 20-40watts and overpower your ears.
    Wattage isnt everything. Efficiency is different for everything.
    An inefficient speaker putting out 500 watts rms isnt going to be as loud or as clear as an efficient speaker pumping out 200 watts RMS.
    Theres no real way to say 1000watts = X2 loud compared to 500watts. theres too many varibles. Enclosure, power, efficiency of components, enviornment it goes on and on.
    You need what? a 3dB increase to precieve something as twice as loud. And you can gain 3dB on the same wattage by just changing one of the varibles. Course after 140dB things start getting funky. But thats entry level competition SPL.
    As said, Caps and battery are a band aid. But on top of that an extra battery is BAD for a car on a stock alternator. You expect the car to charge BOTH batteries and provide power with your system all at the same time? An extra battery on a low amperage alternator will only put more stress on the alternator. Same thing with charging a huge cap.
  5. #25
    Jan 2007
    UK
    An extra battery on the same alternator will put no more stress on the alternator, unless more power is being drawn from the batteries than when you only had a single one..which would make that an unfair comparison.
    Although as you say, just because you have a 1000W amp doesn't mean you're using 1000W constantly.. you may only be averaging 100W or so.
    The table above for current draw to power is laughable... so a class A amp draws the same current to reach 10W as a class D?
    Funny thing is, all of this clever (and frequently misguided) maths is well and good, but I have a 55aH battery and a 100A alternator, driving a car PC, 1500WRMS of amps, a processor, headunit etc.. and my headlights don't dim at all... Maybe my alternator should read 300A?
  6. #26
    Jan 2005
    unless I am mistaken and i can check on my 69 that car stock should have a 45amp alternator, if you have the 302 model then a alternator for a towncar will fit you can get them up to 110amps, I would suggest at least a 85amp
  7. #27
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by mulletboy2 View Post
    Why don't you think it will put more stress? Anytime your batteries voltage is below that of the alternator, the battery is going to put a load on the alternator to get up to the alternators voltage.
    So? All that means is that you are not drawing more than about 1400wrms for any extended amount of time.
    This isn't even clever math. You have 100amps X ~14 volts...Means you have about 1400watts to work with. So if you're lights aren't dimming, you are using less than that. Are you trying to say that that's wrong?
  8. #28
    Jan 2007
    UK
    Quote Originally Posted by XxAndyxX View Post
    Because the same music at the same levels is going to require the same amount of power, regardless of how many batteries there are in a system. Assuming a linear scale (which it's not, but it's more convenient to explain), then if a certain sequence of music made the alternator drop from 14V to 13.2, and then a single battery and the alternator together drop to 12V, then if you had 2 identical batteries in the same condition, the alternator would drop to 13.2, and then both batteries to 12.6V or so. They would take the same amount of time and require the same amount of power from the alternator to collectively reach 13.2V as the single one would from 12V. The difference being, the headlights may not have dimmed with 2 batteries because the system voltage didn't drop as low. Because the same overall power has been drawn, it takes the same time/power to recharge them.
    My amps, headinit, processor, PC, inverter and other accessories have the potential to draw considerably more than 100A... what I'm saying is that just because they have that potential, doesn't mean I need an alternator that's capable of catering for that on a continuous basis.
  9. #29
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Unfortunatly this happens all of the time. people have -lets say- a 65amp alt and a 60AH batt.... they're comming short to feed there audio properly and buy a 100AH yellowtop and put it on the same 65amp alt.....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  10. #30
    Jan 2007
    UK
    Quote Originally Posted by IC-C30 View Post
    There's nothing wrong with that IMHO. Note the different units - Ah is the battery's reserve capacity... a 55aH battery (basically) takes as long to recharge after a given load as a 550aH one does. The only important difference is how low the battery's voltage would have dropped. Just because the alternator is rated at 65A and the battery is rated at 100Ah doesn't mean that the alternator isn't capable of recharging the battery, or recharging it fully... Replacing a battery is usually considerably cheaper than a new alternator or a re-wind. It all depends what you want and what your budget is. I'm not against an alternator upgrade by any means, but I certainly wouldn't recommend one as a matter of course for someone who's just out to enjoy a bit of music on a reasonable budget... there are better areas to spend this money, e.g sound deadening, better speakers, more time and effort in installation etc...
    Just my opinion though
    Mark
