Results 1 to 10 of 11
Thread: Had sound in the house... put in the truck and no more?
    Aug 2005
    Plano/College Station, TX
    Like the title says, I could get sound from my carputer while i tested it in the house, but once I installed it into my truck, I don't get any sound at all from the PC. It's not the connection to my headunit because I don't even get sound when I plug headphones into the back of the PC. Anyone have any ideas?
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    did you look at the settings of your card to see if they were correct, after installing it in the trunk?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2006
    Colorado, but Canadian!
    Did you make sure you plugged it into the green slot!
    Even though I don't see a relation between the following suggestions and moving the PC, it doesn't hurt to try. Just make sure it is not muted. Make sure that the default audio out device is set and not "Not Available". Maybe a failed shutdown before you left the house made xp revert back to previous settings before the drivers were installed.
    Basically check the normal stuff. Then we will go from there.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2006
    Abele, Belgium
    sounds weird but I had it, even twice, that after disconnecting power, when I rebooted my pc, previous settings were lost....
    CLARION HX-D2
    Aug 2005
    Thanks guys. I think I configured my power settings wrong on my OPUS so my truck battery's drained right now. Hooked it up to the charger so I'll give it a go in the morning and let y'all know what happened.
    Aug 2005
    ok well i updated my audio driver, but for some wild reason the windows volume control has disappeared from my computer. It's the one that you find under Start>all programs>accessories>>entertainment. Any idea what caused this to happen? And how can I get this file back?
    Aug 2005
    oh and now that I think about it, I removed the front audio output jack on my case when i installed the computer in the truck. Would that have anything to do with why I'm notgetting any sound from my PC? I've checked all the settings and made sure the onboard sound is enabled as the default sound device. I'm just getting absolutely nothing out of the speakers for any type of audio, mp3, mpeg, wma, avi, etc. etc.
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    Quote Originally Posted by Gearhead61 View Post
    c:\Windows\System32\sndvol32.exe
    or
    start-->settings-->control panel-->Sound and Audio Devices-->Advanced Button
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    Aug 2005
    Thanks legacy. I copied it back onto the computer from my desktop, but that still didn't manage to solve my problem...
    Aug 2005
    Well I solved my problem! It appears the sound output on my motherboard was fried why my M2-ATX decided to fry itself out too. I hooked up the front sound output on my case to the motherboard and I got wonderful sound from it! Another great reason to avoid the M2-ATX like the plague!
