Results 1 to 4 of 4
Thread: why is my amp shutting off
    Dec 2006
    i have a autotek 2000.mm amplifier , and it seems i have 2 turn the gain down low in order for the protect lite not 2 com eon. but i have it connected 2 a crossover which the level is turned up all the way. i was wondering if im gettin the full power from my amp or if it could be the 4 gauge wiring.its cinnected 2 a l7 . with an extra battery just for the system
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    oh god.....
    GAIN-controls are NOT a volume!!!!!.......
    what are the specs of the amp and subs? how thick is your wireing, how big is your battery? what alt do you have?.....
    you really need to provide some more information in order to get any help, really.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    1. You're system is not set up right
    2. Gain is not volume control. Push it up beyond what the amp is capable of handling and you will damage either the amps, speakers or something else. Gain has to be set carefully. You need to take into account input voltage from the head unit, and tune the gain to a specific output voltage depending on where you want it. Not for n00bs.
    3. audiotek is not known for making high quality amps. You're amp says 1000watts at 4ohms, 1500 watts at 2 ohms, 2000 watts at 1ohms. Being a maxxsonics product I can gaurantee that the amps are overrated. At the most id get your amp does 1300watts at 1ohms. Doubt its really clean at that power level.
    4. You're maxing out your gains on your crossover, meaning you're driving it to clip. Most crossovers act as line drivers, meaning they increase the voltage going towards the amp. By doing this your trying to push too much power to the amp. So it's going into protect mode at low gain settings.
    Unplug the amp. and measure the voltage going into the crossover. Write that number down (lets say its 3v)
    Plug the crossover but not the amp back in and measure the voltage coming out of the crossover. Reduce the gain till it matches the figure you got before (In our case 3V)
    Now reconnect your amp and set the gains properly using this tutorial
    http://www.caraudio.com/forum/showthread.php?t=164826
    The only reason you havent killed your L7's is because they can handle alot of power, the amp doesnt put out truly enough power for them, and the amp went into protect to prevent damage.
    oh, and learn to spell
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    L7's arent exactly the cheapest subs to be toying with like that, i would definately do otherwise your subs will do this but out the other end!!!
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  3. amp pop
    By dan__wright in forum Car Audio
    Last Post: 06-16-2005, 05:24 AM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  5. Amp setup. Heat concern.
    By d_sellers1 in forum Car Audio
    Last Post: 07-09-2004, 10:58 AM
