I'm not sure what the exact name of the device is, but I've seen it on here before.
It's basically an AV hub, only for car stereos you wouldn't need the video just the RCAs. Basically it's a little box with inputs for 3 or so RCAs, with a single output that would go to your amp. You can select which of the three input signals you want to go through using a little switch which I'm sure you could find a way to mount in some remote location.
Plug you stereo and your carpc into this, and then you can toggle between the two as needed.
LinkBack URL
About LinkBacks
