Results 1 to 5 of 5
Thread: Too much airspace...can it be filled and if so, what is recommended?
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Thanks in advance to all who respond.
    It seems that I may have an enclosure (mdf ring - 'glass enclosure) with too much airspace. My question is, is it ok to fill some areas around the inner parimeter and if so, what is recommended?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could use some liquid nails to glue in some 2x4 blocks to take up some air space.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    how have you determined that you have too much air space?
    was this an enclosure built for a different sub initially?
    Jan Bennett
    Dec 2004
    Upstate New York
    Instead of doing the "peanut" method, I calculated the air space. Afterwards, I was given some peanuts so I checked it with that method and that's when I discovered I had too much space (and yes, my wife DID tell me so beforehand but being a hardhead, I wanted to prove her wrong...now I must live each day in humiliation ).
    No flames please; I'm getting enough at home
    Quote Originally Posted by RedGTiVR6 View Post
    _
    Mar 2004
    Little Elm, Texas
    hehe - hey! it happens!
    how much too big is it? If we're talking about a smaller percentage of the whole, leave it...a bigger enclosure on that scale isn't that big of a deal...might even be adventageous. Have you listened to it yet?
    Jan Bennett
