Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Audio broadcasting
  1. #11
    Variable Bitrate Pistolen08's Avatar
    May 2005
    Tampabay, Florida
    I am trying to keep my install look stock, so I don't want to have any antennas that would look out of place, and I don't want to remove the factory one, so it seems as though I'm stuck with it. Also, if something happens, and the FCC is knocking at my door I don't want to look suspicious lol (even though I wont be transmitting on commercial frequencies). Once I build the circuit, I can test the antenna and go from there. I just want to freak people out at red lights, etc... lol
  2. #12
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    then just get an amplifier
  3. #13
    May 2005
    Tampabay, Florida
    isn't that what the tunecast mod essentially is? If you compare the power outputs before vs. after the pcb is attached, you can notice significant boosts.
  4. #14
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Pistolen08 View Post
    So, if I want to broadcast at 98.7 MHz, one cycle = (1/98700000 ~= 0.00000001032 seconds) and one quarter cycle ~=0.000000002533 seconds, and at traveling at c (the speed of light), the electrons can travel ~=0.7594 km in that time, so the optimal antenna should be 759.4 m tall (2491.47 feet ~= 0.47 miles). lmao I don't think that will fit in my RSX.
    no.
    300000000/98700000=3.03m
    so a quarter cycle would be about .75m, or 30 inches
  5. #15
    May 2005
    Tampabay, Florida
    Wow, I was quite a bit off lol.
    That sounds a lot more reasonable.
    So frequency (Hz) = speed of light (m/s) / wavelength (in a vacuum).
    If this is correct, the optimal antenna length for the station 98.7 is 30 inches.
    Radio antennas are usually very tall, so how can this be?
    Quote Originally Posted by greenman100 View Post
    no.
  6. #16
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    im sure it has something to with like, if you cna make a 1/4 wavelegth antenna, im sure you can mke a 4x wavelength one too
  7. #17
    Mar 2006
    Colorado, but Canadian!
    1.9in x 2.9in -- 47mm x 73mm
  8. #18
    Mar 2005
    the antenna on your car is about 30 inches, incidentally.
    if you are speaking of broadcast antennas, they are that tall to get above obstructions. the actual antenna element is much shorter.
  9. #19
    Newbie v1per's Avatar
    Dec 2006
    Salisbury, NC
    Yea, the top of the antenna tower (the actual part of the antenna) is like alight bulb while the tower part is just the extension cord.
    Max Messinger
    Computer Expert
    Car Newbie
    2000 Maxima CarPC Progress: 99%--Basic computer fully installed, full stereo overhaul planned for the future
  10. #20
    May 2005
    Tampabay, Florida
    Wow, I always thought that the metal supporting the antenna tower acted as the antenna itself. So, if a typical antenna used at a radio station broadcasts 50 miles radius, mine should reach ~1-2 miles do to interference/size/inefficiency. I will try to build the signal amp next week, once I finish my carpc install. Thanks for your help guys.
    -Elliot
  1. Planned Audio System
    By Fox_Mulder in forum Car Audio
    Last Post: 11-01-2005, 05:57 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
