Results 1 to 10 of 20
Thread: Audio broadcasting
    Variable Bitrate Pistolen08's Avatar
    May 2005
    Tampabay, Florida
    Audio broadcasting
    Hi,
    I have an idea, and want to ask a few questions to see if it's possible. My carpc has headphone + line out + mic jacks on it. The headphone jack goes from the laptop to my amp, and the mic goes from the laptop to a microphone used for my cell phone via bluetooth. I thought it would be cool if I used a modified FM modulator belkin tunecast 2 to broadcast onto a radio station so others can hear. In this case, I edited together some star trek clips relating to the borg. Would it be possible to utilize my car's factory antenna to broadcast this? Here is a picture of the antenna jack on my headunit (I'll take a picture of the antenna cable later)
    This is a picture of the modified belkin's antenna output
    I want to be able to listen to my music regularly, while broadcasting this "hail". Is it possible to have independant channels for headphone and line out? (example: line-out=borg hail, headphone=winamp music). I wouldn't be broadcasting over other commercial stations, and would keep it within FCC regulations. This is just an IDEA, so please don't lock it saying that it is illegal or anything. Here is the audio track I made, so you can get a better idea of what I'm talking about.
    CarPC Hail
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    On your onboard audio card, no you can't have two seperate programs using it at once. You'd really need a second audio output, even something USB like the little turtle beach USB Audio out.
    And, I suppose as long as you know FCC rules about broadcasting in commercial airspace (whether or not there is a station there or not), then we'll leave that up to you..
    Mar 2006
    Colorado, but Canadian!
    I want this Boarg hail!!!
    Resistance is futile, you will be assimilated.
    Well, except for species 8472 that is. They are pretty cool. Fluidic space and all.
    1.9in x 2.9in -- 47mm x 73mm
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    this would be an awesome thing to have if you're caravaning and can talk to each other using something along these lines
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    My friends and I have done this before. When we drove up to denver we used 2 transmitters and a ours was hooked up to both a mic and a dvd player playing a comedy sketch and theirs a mic. We drove for about 1.5 hours and it was like we were all in the same car! We were even as far apart as about 1/5th mile and maybe a bit more, and they were still working. We were using channels that had no stations on it though somewhere in the 88Mhz range.
    Pre-CarPC
    May 2005
    Tampabay, Florida
    Quote Originally Posted by Jahntassa View Post
    Since it is a laptop, I will look into PCMCIA audio cards. So this is my plan:
    Have an application running in the background (when my car is on) outputting to the PCMCIA card, which will run through the tunecast 2 and out to the antenna. The application will loop my borg hail over and over and I will be able to change the frequency (FCC regulations say no overriding commercial stations . Consequences = $10k fine and 6 months in jail). I still need to find out how to use my car's factory antenna with the tunecast 2 mod. Anyone familiar with the standards?
    -Elliot
    May 2005
    Tampabay, Florida
    Is the jack circled in red an antenna coaxial cable? If so, I should be able to directly attach the tunecast pcb to my factory antenna and broadcast from that. Does anyone here have a knowledge of antennas? I need to know if a stock car antenna is capable of broadcasting, since they are designed for recieving. Thanks.
    -Elliot
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    while it would work, it would not work well. automotive antennas are about as good as the foil on the rabbit ears on old tv's.. look for an antenna designed to transmit in the 88-107mhz range.. or make your own, based on wavelength, like I, and im sure others on here, do for wifi
    May 2005
    Tampabay, Florida
    So, if I want to broadcast at 98.7 MHz, one cycle = (1/98700000 ~= 0.00000001032 seconds) and one quarter cycle ~=0.000000002533 seconds, and at traveling at c (the speed of light), the electrons can travel ~=0.7594 km in that time, so the optimal antenna should be 759.4 m tall (2491.47 feet ~= 0.47 miles). lmao I don't think that will fit in my RSX.
    On another note, the whole reason for my having this idea was to have a use for my antenna since I'm not using radio. Do you have any speculations on how far this might reach if I did just plug in my car's antenna to the pcb on the tunecast?
    Here is a pic of the RSX antenna to show how small it is. I can measure it tomorrow, and maybe we can get a better idea of how far it can reach. Thanks for your help.
    -Elliot
    inh
    inh is offline
    Jan 2007
    Fort Riley KS
    hehe nice math!
    what you would do is make an antenna 1/4 or 1/8th wavelength, etc etc... then again this is from someone who's only made antennas for ghz.. so 1/4 wavelegth is like an inch
    it would work better than nothing, but i dunno what kinda of range you would get, honestly
  1. Planned Audio System
    By Fox_Mulder in forum Car Audio
    Last Post: 11-01-2005, 05:57 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
