You wired the HU into the ignition power wire, and not a constant power wire. The HU needs to be "ON" all the time. The screen and drive will shut down, but all radios with memory need to be on all the time. If you take the battery off your cell phone, and the backup battery too, and wait for the charge to go away (3 seconds ish) and put it together, voila. You have erased your phone.
Same deal here. The ignition wire is only supplying power when the car is on or in the acc position. You need to wire it to a constant supply so it is on all the time, but the screen goes on only when the car is on.
I would bet on it.
LinkBack URL
About LinkBacks
