Results 1 to 9 of 9
Thread: newbie wiring question
    Jan 2007
    Cool newbie wiring question
    Ok i am installing two full range boxes in a truck, each with a speaker and 12" sub. I also have two different amplifiers (one is a 400w visonik other is a 200 jenson, each is 2 channel 2ohm stable). My question is how can i wire these 2 amps to both boxes? Would the attached diagram work?
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    blah mixing & bridgin amps FTMFL
    fullrange?...?
    my best suggestion with that equipment would be 1 amp per sub or just use 1 amp period on both subs.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it sounds like he's making a 2-way speaker cabinet like home audio. Personally i wouldn't do it but ifyou really want to then i'd on chan to a woofer, the second chan on the same amp to the second woofer, then on the other amp wire one chan to the 'fullrange' speaker and then the other chan from the same amp to the other fullrange speaker.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2006
    The Colony, TX
    Quote Originally Posted by scott_fx View Post
    he said truck so its not home audio..im assumin
    Dec 2004
    Los Angeles Ca
    oh i know...it sounded to me like each speaker cabinet was going to have two speakers in it. a sub and a fullrange (coax?)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2006
    The Colony, TX
    we all love rear fill don't we
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by MegaloRESE15" View Post
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jan 2006
    The Colony, TX
    my thoughts exactly
    _
    Mar 2004
    Little Elm, Texas
    I hope the OP wasn't run off.
    On a constructive note. If the two speakers are going in the same box, seperate the enclosures. Make it so that the sub has it's own enclosure and the full range speaker has it's own as well.
    Wire up the sub amp ONLY to the subs and the full range amp ONLY to the full range speakers.
    Since its in a truck, I'm guessing he's looking for some more volume as most trucks a very limited on the number of speakers...especially if it's a single cab and it's an older truck.
    Jan Bennett
  1. Replies: 32
    Last Post: 10-13-2005, 01:05 AM
  2. Newbie Inverter Wiring Question
    By arebelspy in forum Power Supplies
    Last Post: 10-06-2005, 03:26 PM
  3. Replies: 7
    Last Post: 06-27-2005, 10:45 PM
  4. deluo gps receiver newbie question
    By boomshakala in forum GPS
    Last Post: 07-25-2004, 06:56 PM
  5. Replies: 13
    Last Post: 06-23-2004, 06:14 PM
