Results 1 to 10 of 14
Thread: computer and sound?
    Jan 2007
    computer and sound?
    Ok, i've read and searched but i still don't understand how it works. I want the computer sound to play though my speakers. I have a head unit with an AUX input. But i always want to use the radio? But i want to hook up a computer radio this way i don't have to go to the head unit every time i change the station. so i can just change it on the touch screen. So heres how i think it works? Get a Y-spliter from the sound card. run those cables to a AUX adapter plug the AUX adpater to the headunit. The keep the headunit on AUX? The buy like a USB radio card? So i can play the radio though the PC then just have it come out of the speakers? Thanks for any help. -cnelson.
    Elsewhere
    The computer's audio goes into the Aux input of yoour headunit.
    Want to listen to the radio? Select it with the headunit.
    Want to listen to a CD? Select it with the headunit.
    Want to listen to the computer's audio? Select it with the headunit.
    You're seriously over-thinking this...
    And USB radio cards/dongles aren't designed to be used while going 60 down the freeway or dealing with buildings and such. Their reception is usually poor.
    If you want PC radio, the best solution is the HQCT (Hi Quality Computer Tuner, I believe). Information here: http://xtronic.be/?id=91&lang=2
    I believe the mp3car.com store has or had them available for purchase.
    If you're going to go that route, there is really no reason to retain the headunit. The PC's audio can go straight to the amp or amps. That's how my system is/will be.
    How about the Wiki?
    Jan 2007
    Ok, so if i do keep my head unit in case i want to listin to the radio or something, but i'd also have a differant screen for the computer so would it go something like this; Is this a pretty easy way to do it?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you got it. but the ground for you computer will be attatched to the 'box to have the pc power on, and power off the right way' aka.. 'psu with shutdown controller'
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2007
    what does psu stand for? and i've searched but couldn't come up with a answer. how to you hook up those shut down controllers? Do you have to tap into the motherboard? Also if i used a laptop how would i run wires to? Like, how would i run a postive and negitive line from it? And if i used the touch screen that would only controll the volume for the computer not for the speakers correct? I would use the head unit to controll the volume for the speakers? Thanks for any help. -cnelson.
    Dec 2004
    Los Angeles Ca
    please read the faq emporium
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Elsewhere
    Quote Originally Posted by cnelson View Post
    Eerything in the blue circle is a DC-DC PSU. There are several models in the store here: http://store.mp3car.com/SearchResults.asp?Cat=2
    They are specifically designed to power a PC, as well as startup/shutdown a PC with the vehicle's ignition.
    Another option is the box to have PC power on. and power off the right way, also known as a startup/shutdown controller, or SSDC.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    I really think you should spend some time reading here: New to CarPCs? Don't know where to start?
    and then here: Attention Newbies! A FAQ to the FAQs
    All of your questions should be answered in those two threads.
    Jan Bennett
    Jan 2007
    Ok, i've read up on everything but i don't really understand one last thing; Do i wire the shutdown/start up contoller right to the bettery? Or the igition? Also does this controll my monitor or just the computer? I think if i'm correct i can set it to turn on boy with the car and off with the car rgiht? -cnelson.
    _
    Mar 2004
    Little Elm, Texas
    wire it to both. It has to have a constant and it has to have an ignition source so it knows how to turn on.
    it can control the monitor if you wire it up as such.
    most DC-DC PSUs have start-up and shut-down controllers built in.
    Jan Bennett
  1. Computer sound noise
    By Psychobiker in forum Car Audio
    Last Post: 06-22-2005, 01:22 PM
  2. Replies: 6
    Last Post: 05-19-2005, 09:59 AM
  3. sound card on home computer....
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 02-24-2005, 10:00 PM
  4. sound computer connection...ive tried everything.
    By supralightning in forum General Hardware Discussion
    Last Post: 09-14-2003, 08:21 PM
  5. Why does computer sound much better than stereo?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-21-2002, 11:01 AM
