Results 1 to 10 of 13
Thread: Two Questions that have gone unanswered
    Jul 2006
    I looked around a bit for the answer to these questions my good friend the google monster gave me an array of different answers and I dont trust it. So i bring it here.
    When you Set your Grounds for your components (Amplifiers, DC-DC, Computer,ETC) Is it a good idea to Ground Everything To a Common Point?
    ..and..
    I Read that your 12v+ and ground should be the same gauge. But i wondered if it would be ok to have a larger gauged wire as your ground.
    Example:
    [+ -]--(fuse)---8Gauge---(amp)===4gauge===[¥] <ground point
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    yup, common ground is best. and yeah, you can have a larger ground, won't gain you anything but it wont hurt anything either.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    common grounds are best if at all possible, but you want to try and keep your grounds as short as possible if possible. It's a delicate balance really.
    a larger gauge ground wire won't hurt anything. Just don't go smaller. This includes your battery ground. If you add on to your battery with an 8 gauge, take into account that added wire on top of the other wires that are coming off of the positive. That needs to be considered when upgrading your factory ground off of the battery.
    Jan Bennett
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    common grounds are best but as said shorter ground wires mean alot too.
    Heres what I did
    1/0ga wire from battery positive to the trunk area
    1/0ga cable from the battery negative to the trunk area
    Positive cable goes to a fused distribution block
    Negative cable goes to a non-fused distribution block
    Everything goes to those blocks
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    _
    Mar 2004
    Little Elm, Texas
    running a dedicated ground from the battery back is a good thing, it's exactly what we've done in our car.
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    i've heard mixed reviews on this (and to me; the way you did it, makes the most sense), what is your reasoning behind doing it this way?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by RedGTiVR6 View Post
    i always thought about doing that. but then the ground wire would be longer instead of short as possible. im assuming you used 1/0awg correct for least resistance?
    _
    Mar 2004
    Little Elm, Texas
    1/0 all the way. If it's connected to the battery, it's not as big of a deal with it being longer.
    By running the ground back, you're not relying on the cars chassis to allow the flow. Many newer cars have silent steel technology that means that they don't ground as well as previous cars.
    This method also means that there's little to no chance of ground loops. If you go through a distro block then from there to the ground on the battery.
    The equivilant resistance of a chassis of a vehicle is around a 4 gua cable from trunk to under hood (remember this from a Dave Navone article from a few years back in Car Audio and Electronics I believe it was). This is due to spot welds and the like. If you're running more than 4 gauge for power...well, you can see the point I'm making.
    Other downfalls? Cost...I guess...but in the grand scheme of things, it's really not that much.
    Jan Bennett
    Jan 2006
    The Colony, TX
    i see
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Hmm, interesting. I use 0/1 gauge for my power and ground to a distro block, but the power is (obviously) direct to the battery, while the ground is to a well sanded point of bare metal. Maybe I should rewire the ground direct to the battery...
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  1. questions which will remain unanswered...
    By Rafster in forum Off Topic
    Last Post: 06-17-2006, 06:36 PM
  2. Have several questions about Incar pc's
    By intuneauto in forum Newbie
    Last Post: 08-06-2005, 12:55 AM
  3. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 03:02 PM
  4. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
