I have 1 12" Type-R, DVC 4ohm+4ohm and a Kenwood KAC-9102D Amp
The "legal" ways to wire it through parallel or series.
I know it is possible to run this amp/sub combo in a way to get a 4 ohm impedance because i have been told it is by professional installers, but they can't tell me how or they will lose their jobs, etc.
how do i do this?
and if it really isnt possible how do i turn down the 850watt rms this app puts out so i dont super-overpower my sub?
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
well the bestbuy installer told me the thing was possible with this amp, but if not im not spending 80 bucks to have it installed. how would i turn down the power of the amp? 850 rms would blow a type-r wouldnt it?
thanks for the help. i was searching the this site and the only other thread aobut this was a bunch of idiots ****ing eachother off with useless information that had nothing to do with the topic hah.
CLARION HX-D2
um well
Rated Power Output:
4ohms (.5% THD):500watts x 1
2ohms (.9% THD): 850watts x 1
Fuse Ratings:
2 30amp Fuses and 1 40amp fuse
even it is a trick its still a good 350 watts over the max for the sub. its almost enough to power two![]()
ok, that will be about 600-700watts at 12v. Those 850watts are probably rated at 14volt or so....
I looked up the specs of the sub.... 500wrms, right? In that case I shouldn't worry about overpowering..... Just be carefull when you tune your amp and the sub will handle the output just fine![]()
CLARION HX-D2
yea the amp runs at 14.4volts
so i tihnk i got this install under control. anything else i should know able? im just gunna run them in series for a 2ohm load in a sealed box (but only because its in an accord)
CLARION HX-D2
