Well, first off you say you have power on the red wire, you should only have power when the key is in the run or accy position
Now check the yellow wire and see if it has constant power
Then check for ground
If you have all those, it should turn on
As far as the dome light goes....not sure what the dome circuit has to do with the radio, unless the original kept the radio on until the door is opened? That part confuses me. If the red wire touched the yellow (constant 12v) then it could have zapped something. Does your cigar lighter work? Its usually the same fuse as the dome light. Maybe thats what you (or Jeep) tapped into for the constant 12v?
LinkBack URL
About LinkBacks
