Results 1 to 3 of 3
Thread: Other Kicker L7 help
    Jan 2007
    Question Other Kicker L7 help
    im new to the car audio stuff..
    i just bought a Kicker 2006 L7 at 4ohms ....
    i just want to no what else to get and what would be the best
    wires
    amp
    if i need a compactor?
    how to wire everything
    i really don't no what much and i have a sub so i want to no what to do
    Oct 2006
    Well for a subwoofer you need the following things : Subwoofer, Amplifier, Power Wire, Speaker wire, remote wire, signal cable, and an enclosure.
    You seem pretty new so I'll try to make this easy...
    -As far as the enclosure, or the box goes, I'd buy a prefabricated box or have somebody make it for you who knows what their doing. Most local audio shops make boxes, and prefabs are easy to find on ebay.
    -If you bought a 12'' L7 then you're going to want about 800W of power, and if you bought a 15'' then you'll want about 1000 or maybe a little more. If you haven't purchased an amplifier yet, you'll need one that fits the above power requirements. I suggest a Class-D amplifier, they have only a single output, which makes the wiring the easiest. Keep in mind that your L7 has dual 4-Ohm voice coils, so wired in parallel you will get 2 Ohms of resistance, so make sure when picking out an amp that the output matches the power needed by the subs at 2 Ohms. A lot of amps advertise their output at the lowest resistance because it's the greatest, so a "1000W amp" might only be 500W when wired to 2 ohms. Other than that, pick whatever brand you want, feel free to post it here after you've made a decision and we'll tell you what we think of it.
    Do you need a compactor? Not unless you have a lot of trash that needs to be pressed into a cube, I don't know how this has anything to do with your subwoofer. Sarcastic replies aside, I'll assume you're talking about a capacitor? No, you don't need one.
    Oct 2006
    Part 2 : Installation.
    You will need the following wires.
    Power cable : 4-Gauge should be thick enough. You need enough to run from your cars battery to your amplifier.
    Ground cable : This MUST be the same gauge wire as the power cable. This will run from your amplifier to a grounding point. Any bare metal point on the car's chassis. Most people use their backseat posts, but this isn't always the best spot, try it there, make sure you sand the pain off, and if you get any noise find a new ground point.
    Signal Cable (RCA) : You will need enough RCA cable to go from your headunit to your amplifier.
    Remote wire : Any thin cable will do since this carries almost no power, you need enough to go from your headunit's wiring harness to your amplifier.
    Speaker wire : 12 Gauge wire should be large enough. You need enough wire to connect your amplifier to your subwoofer's enclosure, and also enough to connect your enclosure to your subwoofer's voice coil, and then finally another couple lengths to connect the two voice coils together.
    now you put it all in...
    The power wire goes off of the POSITIVE (+) battery cable and goes into your amplifiers power connector. It will most likely be labeled +12v or PWR. This will have to run through your firewall, make sure if you drill your own hole that you put a rubber grommet around the hole so that the sheet metal doesn't damage your wire. Most people then run the wire under the carpet and backseat into the trunk.
    The ground wire connects the amplifiers ground connector to a grounding point. As I mentioned before it's common to use the backseat posts, but this might not be the best, only way to know is to try.
    The RCA cable plugs into the back of your headunit and runs to the amplifier's input connectors. You need a headunit that has amplifier preouts in order to hook up an amp.
    The remote wire hooks to your headunit's wire harness, either the Accessory or Ignition wires, I recommend Accessory so you can run your system with the car off. This wire runs to your amplifier, and usually plugs in next to the power and ground wires, it'll probably be labled "REM" or "Remote," this is basically the on/off switch for the amp.
    The speaker wire connects the amp to the subwoofer box. There should be a + and a - wire, hook these to the + and - on the speaker terminals on your box.
    On the inside of the box you then have to connect the speaker terminals to a voice coil. Again, make sure + goes to + and - to -. You then have to connect the two voice coils to each other. Again, + to + - to -, there will be two wires going into one voice coil since it is connected to both the speaker terminal and the other voice coil.
    Hopefully that helped...if not then you're beyond help
  1. Replies: 8
    Last Post: 08-02-2008, 03:44 PM
  2. Kicker 12" L7 HELP
    By tyler3 in forum Car Audio
    Last Post: 01-21-2007, 01:36 PM
  3. RF P5002 and Single Kicker 12" L7 (open to other subs)
    By Cyber_Drone in forum Car Audio
    Last Post: 05-09-2006, 05:28 PM
  4. used kicker L7 15"
    By tokki g in forum Car Audio
    Last Post: 07-10-2005, 02:00 PM
  5. FS: Kicker Solo Baric L7 12 inch
    By EsKALad in forum Classified Archive
    Last Post: 05-23-2005, 11:11 AM
