Results 1 to 10 of 15
Thread: Noob Q: What does "Active" mean?
    Newbie Slimline's Avatar
    Nov 2004
    Arlington, TX
    Just like the title: I read somewhere about someone wanting to go "active" and I have no clue what that means in relation to car audio. In the PC world, I assume it means Active PFC or fans vs. passive heatsinks, but as for car audio - no clue. Help, please? Google gives me too many results to filter (even with "car audio" as helpers)
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    "GOING ACTIVE" or "FULLY ACTIVE" is having hardware which allows control of each individual speaker in your setup.
    and i found that through google in about 45 seconds.
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    _
    Mar 2004
    Little Elm, Texas
    http://en.wikipedia.org/wiki/Active_crossover
    And while you're clicking on links, click on the one in my sig regarding a north texas meet....
    Jan Bennett
    Jan 2007
    Quote Originally Posted by Slimline View Post
    This forum is a great place to learn this stuff, I came here at the beginning of this month not knowing anything and now I feel that I can see the big picture.
    Anyway, the whole reason the terms active and passive even exist is because no 1 speaker can produce the entire range of audio. Obviously a subwoofer isnt going to produce high notes like a tweeter, and vice versa. So every speaker has a frequency range that it produces the best and with the least amount of distortion, and if you try to play a different frequency through it then you'll get crappy sounding music.
    So that's why we need multiple speakers. We break the audible range of sound up into a few different parts. Normally it's three parts, one for the low frequencies (subwoofer), one for the middle frequencies (woofers/speakers that go in the door/mids/whatever you want to call them), and the tweeters. This way, each speaker has its own range of frequencies it can focus on to provide you with the most accurate sound!
    But remember I said you get crappy sound if you use a speaker to play a frequency that it wasnt designed for? Well we need to send only the frequencies that we want each speaker to play to each speaker. That's what crossovers are for! There are two types of crossover -- active, and passive.
    Passive crossovers are the most common and easiest to set up, because speaker component sets already come with them. Just wire them in between the amp and speaker, and go! Active setups are a little harder, though. Rather than filtering out the frequency range for each speaker after the amp, an active setup filters it out before via software (well in our case anyway, since we conveniently have a computer already in the car).
    The reason this causes more complication is because you have to have as many channels in your amp as you have speakers, since you need a dedicated channel for each speaker. You also have to tune your crossover yourself, but that can be a good thing because you'll get to tweak it more to your liking. Active crossovers are also nice because they don't suck power like passive crossovers do.
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    can i dumb the term active a bit for him?
    Active = crossover through RCA(including high level inputs on some units but blah)
    Passive = Crossover through Speaker wire
    simple...or not lol
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    or another way:
    active = crossover before the amp
    passive = crossover after the amp
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2006
    The Colony, TX
    Quote Originally Posted by scott_fx View Post
    or another way:
    thats even more dumber
    Dec 2004
    Los Angeles Ca
    lol
    kudo's to chris though, my favorite 'n00b' on the forum
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2004
    Arlington, TX
    Thanks a lot netchris, that was the missing link. I knew it had something to do with crossovers but other than that I was clueless. Great explanation
    Jan 2007
    UK
    Passive can be crossover before the amp too, it just normally isn't.
  1. noob intruducing myself
    By Shott8283 in forum Newbie
    Last Post: 12-25-2005, 10:32 AM
  2. Are there any ebay traders to watch out for?
    By jeeplaw in forum Off Topic
    Last Post: 06-15-2005, 12:10 PM
  3. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
  4. Replies: 2
    Last Post: 09-30-2003, 08:47 PM
