Results 1 to 3 of 3
Thread: Digital Optical out on Motherboard VS Soundcard
    Low Bitrate fire's Avatar
    Oct 2005
    Melbourne, Australia
    Hi guys..
    i have searched and found nothing that has the direct answer...
    I currently have a CarPC and am sick of the HDD noise in my speakers.. its very faint but there is interference from within the computer… when the mouse is moved, or the hdd is overworked…doesn’t happen at all when I rev the car or anything as I have less than 2 feet of sound cables to the amp.
    I am doing it all again in my next car… but I want optical out to a processor like the alpine PXA-H701. from this I can run super short RCA’s to the amp of my choice…. Optical input amps are rare and is hard to be flexible… this way I can have an amp for front, amp for backs, and amp for subs.. etc.
    Anyway.. My question is.. is optical out on a Motherboard (say ASUS) that claim to be 24 bit as good as a creative Audigy or something with optical out (also 24bit)?...
    I've read that optical doesn’t get processed on board, so does that mean there is no point in buying an external sound card?.
    .. I’d understand if I was using analogue from the computer that I need the best onboard processor…
    BTW im not looking for SPL quality sound… I have the pioneer pro series speakers, and will probably just use them.. Nothing special.. I just want flexibility with clear sound. I don’t even play music all that loud anyway.
    _
    Mar 2004
    Little Elm, Texas
    Not all optical outputs sound the same.
    The chipsets determine how they sound.
    Since you will most likely be going to an outboard processor I would recomend attempting to achieve bit perfect. You can learn more about it here: FAQ: What is Bit-Perfect?
    In short, yes, there is a difference in the sound quality of the optical outputs.
    Jan Bennett
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    I have a gigabyte motherboard that use ALC880 audio chipset (suppose to be 8 channel, high-def audio), i am planning to recycle my old Hoontech Digital Bracket that takes SPDIF signal from the motherboard and convert it to optical for the Alpine processor.
    Hopefully it works fine...
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  3. More help on digital
    By Ascension in forum Car Audio
    Last Post: 08-15-2005, 03:11 AM
  4. Replies: 2
    Last Post: 05-04-2005, 02:43 PM
  5. Optical Out soundcard?
    By chut in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:31 PM
