Results 1 to 10 of 17
Thread: lost half of the sound :mad:
    Dec 2006
    hello ,
    i finished installing my carpc
    intel 2.6
    512 ddr
    80 gb hdd
    creative live 24-bit 5.1
    8" lcd screen
    gps
    obd-II
    after all that and spending over 2k$$$$ i have lost half of sound
    i have creative 5.1 sound card 4 6X9 pionner speakers 350 Watt each 12" 1300 watt sub and 2 amp 250 watt one for 2 speakers and one for sub
    so what can i do now????
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    ...you only have one 2 channel amp... for 4 speakers?
    if this is the case, you can either get another 2 channel amp, or you can get a 4 channel amp, and sell your 2 channel...
    ...Not that I suggest it, but you could run the two left speakers in parallel, and the right two speakers in parallel, that would work for now... but it would change the ohm's and ****...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Jan 2007
    I'm pretty certain he can connect the left speakers to 1 channel and the right speakers to 1 channel..
    @colombiano
    What do you mean you lost half sound? Where is the sound coming from? Where is it not coming from? How do you have everything connected?
    Dec 2006
    thanx for replies
    i have 2 amp for 4 speakers not 1 amp
    and about losting the sound am comparing with my old installation kenwood head unit
    carpc installation done
    intel 2.6
    512 ddr
    80 gb hdd
    8" lcd screen
    gps
    obd-II
    mitsubishi galant (8g 1999) 2000cc
    Nov 2004
    NY
    oh ok, you're upset about the sound quality... or volume?
    If its the volume... did you retune your amps, for the kenwood headunit prob. had something like a 2-5V line for the rca's into your amp, where as the sound card is something like .5V, meaning you're going to have to retune your amps...
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Dec 2006
    the quality and volume i didn't change any thing in the amp and speakers install do u think i have to change the sound card again its creative 5.1 live 24 bit
    intel 2.6
    512 ddr
    80 gb hdd
    8" lcd screen
    gps
    obd-II
    _
    Mar 2004
    Little Elm, Texas
    btw - instead of puttin gyour specs in your sig, there's a better place for them now....so you can reserve your sig for other things: http://www.mp3car.com/vbulletin/show...518#post987518
    regarding the quality and hte volume....have you properly tuned your amps? http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning
    have you adjusted all of the volume controls on the PC?
    have you checked your voltage outs of the creative card? chances are it's not high enough.
    Jan Bennett
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    More than likely the outputs of your soundcard are nowhere near as high as the outputs of your old headunit. If you haven't adjusted the gains on the amp, you may want to start there. You may also need to look into line-level amplifiers to 'boost' the voltage output of the soundcard.
    Dec 2006
    how can i boost them???
    intel 2.6
    512 ddr
    80 gb hdd
    8" lcd screen
    gps
    obd-II
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Are you running the carpc through the HU aux or straight to the amps?
    Is it possible the voltage is not adequate enough for it to get a proper signal from either HU or soundacard...?
  1. FM sound coming from tuner card not sound card
    By Ascension in forum Newbie
    Last Post: 07-18-2005, 05:24 AM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. sound card help...
    By pimpmode in forum General Hardware Discussion
    Last Post: 06-02-2005, 12:32 AM
  4. Sound not very loud have i bought the wrong amp
    By rickyaswell in forum Car Audio
    Last Post: 09-26-2004, 11:23 PM
  5. Sound Quality with External USB Soundcard
    By nirvanades in forum General Hardware Discussion
    Last Post: 08-12-2004, 06:34 PM
