Results 1 to 3 of 3
Thread: sub ohms
    Jan 2007
    england
    sub ohms
    hi there i am not to good when it comes to audio systems so help is much appriciated...
    i have 2 12" dvc directed 500wrms 750w output subs in the pics below what ohm r they configured to 2 or 4 i havent a clue?there is a cable running outside the box to each terminal?
    Oct 2006
    That is the strangest way to wire two subs together I've ever seen.
    From those pictures we can't even tell if they are wired in series or parallel, I'm guessing parallel, but that is nothing more than a guess since I can't see which terminal is positive and which is negative.
    The resistance depends both on the subwoofer and how they are wired. You need to tell us how many voice coil each subwoofer has, what resistance each coil has, and how the coils are all wired together. Without knowing that there is no way to tell the total resistance.
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    ...or just grab a multimeter, set it to resistance (20Ω is plenty) and check the resistance on each terminal.
    You can also check the resistance of each coil and then wire them however you wish.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  1. dual vioce coil sub/amp wiring
    By hotponyshoes in forum Car Audio
    Last Post: 12-24-2007, 12:20 AM
  2. ***Big 5 or 6 channel amps***
    By 3onDubs in forum Car Audio
    Last Post: 03-17-2006, 11:02 PM
  3. Amp/Sub Ohm's Confusion
    By mattwz in forum Car Audio
    Last Post: 07-03-2005, 10:47 AM
  4. Replies: 2
    Last Post: 04-24-2005, 06:01 PM
  5. car speaker ohms?
    By etrik in forum Off Topic
    Last Post: 07-21-2001, 04:58 AM
