Results 1 to 4 of 4
Thread: XM Direct Sound Quality?
    Jan 2007
    South Jersey, NJ
    I just installed my CarPC and got it all up and running. My mp3's off the hdd are crystal clear, but when i listen to audio from XM it sounds pretty crappy. There's no high end clarity and its very bass heavy. I've plugged in some speakers directly into the RCA outputs of the XM direct unit and it sounds the same. Is this the quality that comes out of these units? I had an XM roady in my last car hooked up through a tape adapter and it was light years ahead of the XMDirect unit in sound quality.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    do you have digital inputs on your soundcard? if so there is a hack for the xmdirect that will give you digital output...that may help you in your sq quest.
    New System in progress:
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2007
    South Jersey, NJ
    No, no optical inputs. But i mean, my little roady via a cassette adapter provided much better sound. No one else has any sound quality issues with their XM direct box?
    Aug 1999
    Washington D.C.
    The sound quality coming out of the XM Direct vs. the Rodie should be equivalent. On my system mp3s and other media sound better because they don't use all the compression that XM uses.
  1. Replies: 492
    Last Post: 11-07-2010, 10:16 AM
  2. XM Direct + Serial = Mouse?
    By jpsndtek in forum Hardware Development
    Last Post: 12-23-2007, 12:56 PM
  3. Xenarc 700TSV, Xm Direct, etc for sale
    By Zinjamaster in forum Classified Archive
    Last Post: 10-02-2006, 07:57 AM
  4. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 02:07 PM
  5. XM Sound Quality?
    By nFiniteTuning in forum General MP3Car Discussion
    Last Post: 01-29-2005, 11:20 AM
