hurtz range is supposed to be:
45Hz to 6kHz
the frequencies i'm sure. I answered my own question.
I have a 15 inch EV force speaker thats in a piano cab, 160watts rms, rated at 8 ohms, would it sound like crap put in a sub box and hooked up to me amp?
looks pretty bomb proof...
45Hz to 6kHz
What are the t/s specs on it, or the model number?
well i actually have a knockoff EV, its in a Kaman keyboard amp, its most likely very close in specs...
SPECIFICATIONS
Nominal Basket Diameter 15"
Impedance 8 ohms
Power Rating (EIA RS-426A) 150 Watts
Frequency Response 45Hz - 6kHz
Sensitivity (1W/1m) 100dB SPL
Voice Coil Diameter 2.5" / 63.5mm
MOUNTING INFORMATION
Overall Diameter 15.1" / 384 mm
Bolt Circle Diameter 14.6" / 371 mm
Baffle Cutout Diameter 13.9" / 353 mm
No. Of Mounting Holes 8
Overall Depth 6.4" / 163 mm
Magnetic Assembly Weight 10.0lbs / 4.54kg.
Net Weight 12.8 lbs. / 5.8 kg
MATERIALS
Basket Cast Aluminum
Magnet Ferrite
THIELE-SMALL PARAMETERS
Resonant Frequency (fs) 40 Hz
Impedance (Re) 5.2 ohms
Total Q (Qts) .51
Compliance Equivalent Vol. (Vas) 297.4 liters / 10.5 cu.ft.
Voice Coil Overhang (Xmax) 3.3mm
Surface Area of Cone (Sd) .08553 m2
Efficiency No. % 3.3%
Diaphragm Displacement Vol. (Vd) 855.3 cm2
any ideas?
phooooh..... the speakers isn't likely to handle much excursion, and since the lowest frequencies produce much excursion I don't think it is a good idea using this speaker as a sub. Other thing is efficiency..... 3.3% meh???? That is really low, never seen anything like it even. And one last thing: the FS is 40Hz,which is pretty high, considering you normally double the FS on your tuning-frequency. In this case that would be 80Hz..... At the x-over point the sound of the speaker will be easily located and that's something you don't want in a sub. Last issue: We let most subs play from 50Hz or less..... That's not gonna happen, so you're letting it handle a too wide frequency-range.
Conclusion? you can not use this speaker as a sub.
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
thank you sir! question answered!
