Have you checked out your User's Manual to find out what it says may be the cause of your proplem. There are many different types of problems that may be going on with your amp, for example:
1. You may have your speakers that are hooked up incorectly to that amp.
2. You're speakers/wires may have shorted out.
3. You're amp may be going out internally.
If you're problem is 1 or 2 then Does this still happen while your speakers lines are disconnected from the amp?
Although, if you're problem is #3 then there isnt much you can do but get a new amp, because it might not be easy to repair the amp.
But keep in mind that this forum is dedicated to carpc's, so you might be better off directing the remainder of your questions to the original manufacture of your product or to a dedicated car audio website->Originally Posted by Red GTi VR6
LinkBack URL
About LinkBacks
