you shouldl be fine. i run all knukonceptz wires too, and they are much better quality then monsterwire. i had 4 guage running a xtant amp @ 75x2 and 300x1 with a 100 amp fuse on that amp and i never had a problem, no headlight dimming or anything.
i am running the following
600w amp (100 x 2 at 2ogm)
600w amp (50 x 2 at 40hm)
Dsatx PSU
i was going to use a distro block, running 4 gauge from battery and 8 gauge to each of the above is this correct and what kit can i use from
http://knukonceptz.com/
thanks
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
thanks another question is how to i turn on 2 amps with the dsatx i know you use a relay for one is it the same for 2?
Why not just wire them to your ignition like normal?
i'm not familiar with the dsatx, but if you're using a relay you can wire more then two amps to a single relay w/o a problem.
M10k
My Car Pc Install
My Boat Pc worklog
1.9in x 2.9in -- 47mm x 73mm
after reading the posts here is what i understand correct me if i am wrong:
i need a 12V 30amp SDPT relay
85--> 12V
86-->Dsatx
30-->Amp Lead #1
87-->Amp Lead #2
does this sound right?
and how big of a fuse should i put in bront of the distro block, 125?
Right relay, wrong wiring.
85 - Remote lead from DSATX
86 - Ground
87 - +12V
30 - Remote leads to both amps
As for the fuse, add up the max current each component in the circuit will use (the built-in fuses on the amps will give you an idea each one's max current consumption) and use the same size fuse (or next size up if there's not an exact match).
-Jay
1997 Chevy S-10, ext. cab
CarPC Progress: 75% - Functional, but not quite finished.
Check out my progress.
