Results 1 to 10 of 11
Thread: does the big 3 really work
    Feb 2007
    new york
    i am in need of a hig output alternator but i recently found out about this big 3. does it really work cuz if it does that would be great, currently have a heavy system and wondered if it did work and if someone had some step by step pictures that can help on the installation. please let me know thank you
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it works, but has its limitations. you can't add more then what's there, it'll only make what is there accessible.
    check out knuconceptz web site for a tutorial IIRC
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Feb 2007
    new york
    do 2 batteries affect the wiring of the big 3
    but does it have to be wired differently with two batteries?
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    all the big 3 does is reinforce the power cables from the alternator and such with a larger gauge cable, so I don't see why it would affect how you wire a second batt
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Feb 2007
    new york
    just wanted to know if it could still be done in consideration that i have an isolator and a battery in the rear separate for the system alone
    Feb 2007
    new york
    i c ur from ny , do u know anyone in the queens area who knows how to wire it correctly
    Nov 2004
    NY
    yeah, it can still be done correctly, if you look at what the Big 3 really does... all it does is, add a lets say 0gauge cable from the alternator to the batt in adition to the stock cable, then run a new 0guage cable from the battery to the chassis, then run a new oguage ground from the chassis to the engine/mounting bolt on the alternator.
    Basically all its doing is reinforcing the cables that are already there, i don't see how this affects your second battery, other then giving it more room to breath...
    http://forum.sounddomain.com/forum/u...=5;t=007801;p=
    And sorry, I'm from Long Island, and unfortunatly don't know anyone that knows the difference between there boombox and a mcintosh.... I do everything myself with help from the internet.
    Basically get some big cable and go wild
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Is there a difference between a boombox and an Mc? really? So you think I should upgrade to a boombox then?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Nov 2005
    UK
    not an expert here by any means, but surely if your gonna be upgrading your alternator, you should be doing the big3 anyway. so why not start with the big3
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    It does make a big difference on some setups.
    Basically it allows your system to push out its near maximum potential. Forget a capacitor 90% of the time, the big three is usally needed for systems running high wattage and dimming headlights.
    On my car it isnt the big three, its more like the big 5. Since the battery is just behind the headlights underneath the airbox and tucked away its hard to get at it, so my car requires more work.
    1 Wire from battery positive to battery terminal jump point
    1 wire from positive jump point to alternator positive
    1 wire from negative battery terminal to negative ground chassis point/jump point
    1 wire from battery negative terminal to engine block
    1 wire from Battery negative to another spot on the chassis just for added benefit.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 12:17 AM
  2. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 07:22 PM
  3. Will a Powermate work with iGuidance?
    By Troy McClure in forum Input Devices
    Last Post: 03-08-2006, 09:55 PM
  4. help me on my fab work (big pics...56k no)
    By nappyjim in forum Fabrication
    Last Post: 01-31-2005, 06:26 PM
  5. Nissan 100 NX (1600) part II (getting it all to work
    By videodok in forum Show off your project
    Last Post: 05-21-2004, 04:32 AM
