Page 1 of 16 1234567891011 ... LastLast
Results 1 to 10 of 156
Thread: PC audio extreme,competition/studio level...
    Oct 2004
    NY
    alright, I've been active on the audio software thread & the usb vs optical thread & I've been cluttering them up enough with my off topic posts, so for this one I figured I'd just start a thread...
    I guess the average guy who clicks on this thread is going to just think this is nutz, but there are a few here who understand what I really want to achieve
    the end goal of my project is to have all audio in my new car originate from the pc... I will have no head unit... I also don't have any room for a separate processor control display, so I've been shying away from using an alpine processor which was the original consideration...
    I then considered doing all audio processing on the PC, my plan was a dual PC setup that used the rear PC as kinda an audio server, doing all processing through console & vst plug ins ... outputted thru some form of DA conversion.... while this is still a viable option for me, in my research to find the equipment to do audio on the PC & through a mention by red, I found something pretty cool...
    a rack mount pro audio processor that does everything that would ever be needed to tune a car... it has 8 outputs & oh well,here :
    Product Description
    The DB Drive Rack 480 stands at the heart of the Drive RackŪ system. The dbx Drive Rack 480 includes 4 inputs and 8 outputs which can be tailored for any configuration. By including every form of processing necessary to drive the signal from the mixer to the power amps, such as pre-crossover EQ, notch filters, speaker delay, multiple crossovers, speaker compensation equalizer, driver alignment delay, and compression/limiting, the 480 is truly the only box you’ll need for any sound system application. Two real time analyzers can be run simultaneously with RTA source inputs capable of being remotely switched on the fly. The 480 is fully programmable from the front panel, with the 480R remote control, or through a computer via the GUI port.
    dbx Drive Rack 480 Features
    4 Inputs and Outputs with routing
    31 band graphic or 9 band parametric equalizer on every input (pre-crossover)
    Dual Real Time Audio Analyzers
    Butterworth, Bessel or Linkwitz-Riley crossover filters
    27 Different Crossover Configurations
    Time Alignment and Transducer Alignment Delays
    Compressor/Limiter on every output
    Speaker Compensation EQ (post crossover)
    Multi-level Security System
    Separate House and Show EQ with individual lockout
    Triple redundant back up of all parameters when running network, 480R and PC GUI
    TYPE IV™ Conversion System
    Electronically balanced/RF filtered XLR Inputs and Outputs
    Proprietary RS-485 Control Network
    RS-232 PC Interface for computer display and configuration
    Technical Details
    Specifications
    Inputs
    Number of Inputs: 4 (Inputs 3 or 4 can be selected as an RTA Mic input)
    Connectors: Female XLR
    Type: Electronically balanced/RF filtered
    Impedance: >40kOhms
    Maximum Input Level: Hardware selectable for +30, +22, +14, dBu
    Maximum Input RTA Level: -10 dBu
    CMRR:
    >40 dB typical
    >55 dB at 1kHz
    Input Gain Range RTA: 10 dB to 70 dB w/60 dB typical
    Outputs
    Number of Outputs: 8
    Connectors: Male XLR
    Type: Electronically balanced, RF filtered
    Impedance: 120 Ohms
    Output Transformers: Optional
    Maximum Output Level:
    +25.5 dBu into 1kOhm
    +22dBu into 60 Ohms
    A/D Performance
    Type: dbx Type IV™ Conversion System
    Dynamic Range (line):
    >112 dB unweighted
    115 dB A-weighted
    Type IV™ Dynamic Range:
    127 dB with transient material, A-weighted, 22kHz BW
    125 dB with transient material, unweighted, 22kHz BW
    119 dB typical with program material, A-weighted, 22kHz BW
    Sample Rate: 48kHz
    A/D Wordlength: 24 bits
    D/A Performance
    Dynamic Range:
    112 dB unweighted
    115 dB A-weighted
    Sample Rate: 48kHz
    D/A Wordlength: 24 bits
    System Performance
    Internal Wordlength: 48 bits
    THD + Noise: 0.003% typical at +4dBu, 1kHz, 0dB input gain
    Frequency Response: 20Hz- 20kHz, +/-0.5dB
    Interchannel Crosstalk: <-85dB at 1kHz, 0dB input gain
    Pre EQ
    Type: One 31-band Graphic EQ per input channel, or 9 band Parametric EQ per input channel
    RTA can be substituted for EQ in channels 3 and 4
    Range: +/-12 dB range
    Notch Filters
    Number: 1-5 per input channel not to exceed 10 for all input channels
    Pre Delay
    Length: 680ms/channel
    Crossover: Type: 1x2, 1x3, 1x4, 1x5, 1x6, 2x3, 2x4, 2x5, 2x6, 2x7, 2x8, 3x4, 3x5, 3x6, 3x7, 3x8, 4x6, 4x8
    Filter Type: Butterworth, Bessel, or Linkwitz-Riley
    Slope:
    6, 12, 18 or 24 dB/octave for Butterworth or Bessel filters
    12, 24, 36 or 48 dB/octave for Linkwitz-Riley filters
    Post EQ
    Type: Parametric
    Number: 4 EQ bands per output channel
    Range: +/-15 dB range
    Dynamics
    Type: Compressor/Limiter with PeakStopPlus™
    Attack/Release: Program Dependent
    Linking: All 8 bands are linkable
    Post Delay (Driver Alignment)
    Length: 170 ms per output channel
    Pink Noise Generator
    Position: Pink noise inserted on selected input(s)
    Phase Compensation
    Number: One per output channel
    Amount: 0-180 degrees phase shift
    Output Polarity: Reversible
    Miscellaneous
    Network: Proprietary RS-485 Backbone
    GUI: RS-232 interface for computer display and configuration
    RTA Microphone: Optional
    ROM Upgrade: Flash upgradeable through RS-232
    Power Requirements
    Watts: 100-240V - 50/60 Hz; 35 Watts
    Dimensions:
    Height- 3.5"
    Width- 19"
    Depth 12.15"
    Weight: 11lbs.
    my thinking is, that if I'm going to go out & build a pc for this, & then add the harware & software necisary, including high end hardware anyway, the cost may not be way cheaper than a unit like this anyway.... this thing is like $2,500
    the software for this is totally cool, you can do anything through it's gui & never have to touch the unit in the trunk past initial setup.....
    this is professional studio grade stuff, so the quality is there, & interface is ideal.... it even has real time analyzer funtions built in... the possibilities are pretty cool with this thing... I could call up the rta in roadrunner & embead it as the visualization, talk about a cool visualization
    in the end, what difference is it to me weather my audio is being processed by a core 2 duo slave unit with da converters running console, or weather it's all being done with this stand alone unit... somehow I think the rackmount will be more reliable & less fussy, not to mention booting in maybe 5 seconds
    heres a screenshot from the software:
    Oct 2004
    NY
    I guess I'm just looking for thoughts or opinions on a setup like this.... any input is good input....
    aside from the price & the space required, anyone see any drawbacks that I might not see?
    the more I think about this, the more I think this might just be the ultimate solution
    Mar 2006
    Colorado, but Canadian!
    I think it looks awesome. Scares me though... Just the price tag. I could never afford it, nor need it!
    But it is definately a cool piece of machinery.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2004
    NY
    yeah, I just put a snipe bid in on one on ebay
    crazy stuff I guess... this is just such a sweet piece... I'll know in a little while weather I win that one or not... it's cheap & the sellers a bit shady, but I would only do a cash pickup or he can go screw himself..., he's not to far from me really... if I get this one it'll be relatively cheap
    Mar 2006
    a snipe bid means you will know in like 7 seconds!
    Low Bitrate PSYKO_Inc's Avatar
    Oct 2006
    Fairfield, CA
    I don't really have anything useful to add to the thread, but I gotta say it's a damn good concept. I'm definitely looking forward to see what happens with this. Is this going in the Caddy?
    -Jay
    1997 Chevy S-10, ext. cab
    CarPC Progress: 75% - Functional, but not quite finished.
    Check out my progress.
    Oct 2004
    NY
    yeah, in the caddy, I just won it $1275.... damn cheap...... now to see if it's bull**** or not.... I'm going to go out there & pick it up or no deal...
    wow, this should be an interesting install
    Mar 2006
    Quote Originally Posted by turbocad6 View Post
    Congrats on sniping!
    Jun 2005
    chicago, Illinois
    Very ambitious! Hope it works out well for you.
    PROGRESS:
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    haha way to snipe! Awesome! There are no drawbacks from what I know. If you have the space in the trunk, use it. Altering the power supply should not be too hard. Ther is one definite advantage this has over software...less risk of blowing up drivers because something went haywire in the software or computer. I'm Jealous!
  1. PC audio only when HU is on
    By NeX in forum Car Audio
    Last Post: 03-16-2006, 03:56 AM
  2. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  3. How much line level does the Epia M Audio have?
    By orangewhip in forum Car Audio
    Last Post: 05-20-2005, 08:56 PM
  4. Car PC Audio Design
    By sza in forum Car Audio
    Last Post: 10-27-2004, 10:08 AM
  5. Experienced PC guys needs Car Audio Primer
    By SwapMeet in forum Newbie
    Last Post: 02-10-2004, 05:33 PM
