Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: Motor City 160 amp H.O. Alternator - THUMBS WAYYY DOWN
    Nov 2005
    I'm green, MCR tech cust support is red.
    We just installed this alternator and it does not charge… Voltage is 12.4 at idle with nothing on… with load it drops well into the 11v’s.
    I am currently reinstalling my old alternator.
    that means that you are doing something wrong.
    did you upgrade wire? did you check for belt slip? does output change with increased rpm? if you upgraded wire how did you wire it?
    Yes, yes and yes.
    I had upgraded wire already in place, an extra (parallel) 4awg wire on both positive and negative sides.
    The belt is good and tight, also its brand new because the original had a tear.
    I also drove it for a short ride and didn’t smell any burning.
    During my ride it was clearly evident that the alt is not charging at idle; As soon as I rev the car everything in the car lights up, even the blower motor speeds up. So yes, output does change with RPM… At cruising speed the output was fairly steady around 14.4v. But again, as soon as I stopped at a light the voltage dropped slowly down below 12v’s.
    simple solution....you have an rpm problem that can be solved with smaller pulley, if you measure what is on there now i will send smaller
    The pulley looks about 2”and 3/8”
    Here is a photo of a tape measure over the pulley…
    More importantly, how is the pulley attached… I have no tools for pulling or pressing pulleys.
    And also, if the unit requires a smaller pulley to function at idle… shouldn’t this have come on the unit?! I mean this wasted a solid 4hrs of my time today installing the alternator and then reinstalling the original alternator.
    At this point I've spoken to caraudiobook.com and learned how exactly these units are rewound and why the need smaller pulley's to put out the same power as a stock unit at idle; I have also been informed by other ClubGP members that MCR did the SAME thing to them.
    So I filed an Item not complete claim with paypal to make sure that I get the rest of the item. BUT this ends up in my mailbox minutes later.
    the pulley is not pressed on, you simply use impact wrench with 15/16" socket and remove, change pulley and replace nut. very simple. as far as pulley being put on here it is only in very few cases that the smaller pulley is needed. you cars rpm has to be slower than normal causing problem. when installing a high amp alternator there are always possible tweaks to the system that need to be done. also what is the deal with filing a claim with paypal? at any point did we tell you we would not help solve your issue?
    next email before I could type up a reply
    after thinking about your problem it is clear that a return and refund is best for you. send it back and we will refund purchase price.
    quote:
    The first words out of your mouth were; “that means you are doing something wrong”; Which is arrogant at best.
    I filed a claim to cover my bases, it won’t effect you in anyway unless the claim were to escalate…
    I appreciate the refund; the item will be mailed via Fed Ex this afternoon.
    You can also ”mutually agree not to complete transaction” on Ebay’s dispute console to receive your final value fee back; Also when you refund through Paypal they will refund any fees you were charged by them.
    ARROGANT? YOU DID DO SOMETHING WRONG! WHEN INSTALLING A HIGH AMP ALTERNATOR THE SYSTEM SOMETIMES NEEDS TO BE TWEAKED. BEFORE YOU EVEN QUESTION US AS TO HOW TO PROCEED YOU FILE A CLAIM. THAT MY FREIND IS THE MOVE OF A COMPLETE IDIOT! DO YOU THINK WE HAVE ALMOST 3000 + FEEDBACKS BECAUSE WE DO NOT TAKE CARE OF THE CUSTOMER? WE WILL GLADLY REFUND YOUR MONEY AND BE DONE WITH YOU WITH OR WITHOUT OUR FEES THAT WE HAVE INCURED.
    I’m assuming that the upgraded alt has a larger stator, which required larger gauge wire for the windings… With the limited space inside the stock case you weren’t able to fit as many windings. This creates a situation where you need to spin the alternator faster in order to have enough electrical potential to push out power. And you didn’t have the proper pulley on it, so the rotor isn’t spinning fast enough to create power at a 650rpm (stock) idle. The fact is the unit either should have had the proper pulley on it, or had more windings. The listing clearly stated that it produced 70-80 amps at idle. I don’t see how a slight change (say a 10% overdrive) in the pulley size could have created those numbers after seeing virtually nothing with the pulley that was on it. And decreasing the pulley size even smaller only increases the chance of bearing failure. So I weighed the options and opted out.
    But this argument ended this morning when I sent the unit back. So have a nice life.
    you must be some kind of moron! you tried to install one high amp alternator and we have sold thousands and you think you understand more of the intricacies than we do? get real! a 1/4" smaller pulley would have completely solved your problem, it was that simple. i guess we must be fooling all those other people and you figured it out. go away
    Nov 2005
    Great company, would do "business" with again....
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    thats funny... most of high amp alts have low volts at idle. I have one, and know of others that have high amp units. None of which are worth **** off idle, even though they are supposedly putting out more current at idle that the stocker. The low voltage thing was a killer for me. I took mine off like you, who has time, or wants to upgrade to dimming lights.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    thats why you do serious research before you buy an alternator.
    I plan on buying a police alternator for my car. Basically its the same alternator that they put in Police Intrepids. Chrysler sells it for 300. Puts out 30 more amps than stock and alot more amps on idle.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Farrow099 View Post
    As proph said, HO alternators do not put out very much power at low RPM's. This is a common thing. As far as I am concerned, you bought a product that you did not research. When they say 70 amps at idle, that could mean anything. My rx330 idles around 1000rpm, where as my civic idles close to 150-200. It all depends what you have. So a blanket statement like "70A at idle" should be taken cautiously.
    I think you are completely in the wrong here. They guy sold you a HO alternator, and you did not realize that the downside of a HO alternator is exactly what you mention. On some cars, a smaller puller is required to make more power if you will be city driving and your car has a low idle. Simple math/physics.
    If you are getting your money back, and he is getting his alternator back, then this is a moot point, but still you should know what you are buying.
    1.9in x 2.9in -- 47mm x 73mm
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by 2k1Toaster View Post
    That's HIGHLY UNLIKELY.
    Seems like your Civic's tachometer starts at the 500RPM mark meaning that what you're looking at is 650 ~ 700. That's plausible.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Mar 2006
    Quote Originally Posted by DJiK View Post
    I have it set to maximum efficiency. My car is silent when idleing and it is a gas engine.
    Go Japs!
    Apr 2005
    Care to elaborate?
    Did you physically turn the idle screw as far down as it could go without the engine stalling?
    Mar 2006
    Care to elaborate?
    No. I didn't turn the screw down. What happened was I went to the Honda Dealership and asked them to program it to run at low idle. Basically turns the screw down electronically at a variable amount. It only gives the engine enough fuel to barely be functional (within honda specs). But if I punch the pedal down, it gives me the power within a fraction of a second.
    Not sure of the specifics because I am not a car guy, just a computer guy, but basically it is now wasting very little fuel.
    Cost me $80 for the "tuning". I believe it was a ECU flash to a leaner run or something. 7th gen Honda civics usually get around 32mpg. I can get around 39 to 42 if I am doing 1 nothc more aggressive than granny driving which I for the most part do around here.
    Mar 2006
    Although in my old subaru, it idled too rough so I took a dinner mint and some duct tape and taped it back there. That "idled" around 1500rpm! It was old and dying. It was my last hope at that point!
  1. Replies: 97
    Last Post: 03-10-2013, 05:28 PM
  2. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 09-05-2012, 10:43 AM
  3. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 02:41 AM
  4. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 01:45 AM
