Results 1 to 7 of 7
Thread: Getting SQ from an external CD Drive - possible?
    Nov 2006
    Okie dokie, i'm a newbie to the carputer scene, so be easy on me if i say something stupid that doesn't make sense.
    Here's my situation, i'm installing a car pc and want the audio to operate purely through the computer (this is going to be a headunit-less install). I've got an Alpine PXA-H701 processor that is going to be used as the link between the computer's sound card and amplifiers and for sound quality i still want to be able to play directly from a CD (not just from files stored on the computer).
    Now, my carputer is going in the boot, no exceptions, which makes things a little inconvienient as far as having a CD Drive i can insert CD's into while driving... (I plan to have a CD Drive up front with me). The mere fact that it's in the boot means the distance between it and me is too long to consider using an IDE connector, so i've been looking at using an external USB CD Drive.
    The problem i see with this is, that unlike an internal IDE CD Drive it won't have a direct connection to the sound card, so i worry that any audio processed through it will be routed through on board sound or extra steps which will degrade the signal quality. Can anybody explain for me whether this is a genuine concern as far as SQ goes and explain the process the audio signal would follow going from an external drive that was connected via USB? Would it still get routed through the sound card once it reached the computer? Is the fact that it is travelling over USB first a concern?
    Is there any other feasible options for my given situation that allow me to have a CD Drive that runs through the carputer, provides me with SQ and uses a cable interface which is capable of being extended the length of the car to get from the boot to me up front?
    Any help or words of wisdom on this is much appreciated, cheers, Bryce.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    sound is still transmitted on the USB cable and the soudn leaves the computer via tha soundcard just like anything else. No issues with SQ as far as I have seen. You wil be fine.
    _
    Mar 2004
    Little Elm, Texas
    actually, you need to research Bit-Perfect. Because even using an external sound card, Windows XP will resample the audio stream.
    Search this forum for the term 'Bit Perfect' and you can even narrow it down to threads that I've started. You will find a FAQ in the FAQ forum that's written about bit perfect.
    You can also hit up the MP3Car wiki and search for bit perfect for a wiki article I've written on it.
    What you are going to be doing is essentially the exact same thing I was doing in my car when we won the 2 world titles.
    Jan Bennett
    Oct 2006
    So if I do it will I win a world title?
    j/k <3
    _
    Mar 2004
    Little Elm, Texas
    depends on the rest of your set-up... but it could!
    Jan Bennett
    Jun 2005
    chicago, Illinois
    Red is the shinning example that dreams do come true.
    PROGRESS:
    Nov 2006
    Thanks for all the help Red, i'll have a read up on it when i get a spare moment and get back to you if i get stuck or confused, cheers, Bryce
  1. cd-rom drive as cd player
    By sohaibma in forum Newbie
    Last Post: 12-04-2006, 04:45 AM
  2. My hard drive situation
    By PhatHam in forum Newbie
    Last Post: 10-26-2006, 01:50 PM
  3. Replies: 4
    Last Post: 07-26-2006, 05:03 PM
  4. Problem with CD drive
    By Psychobiker in forum General Hardware Discussion
    Last Post: 04-27-2005, 12:06 PM
  5. External USB DVD Drive
    By banks in forum General Hardware Discussion
    Last Post: 02-02-2005, 12:07 AM
