Results 1 to 10 of 11
Thread: Unamplified HU AMP question
    Low Bitrate Gamer64's Avatar
    Feb 2006
    Holland
    Hey guys,
    In my car i have a Bose Sound System. In the HU that comes with it is not a built in AMP. The AMP that belongs to the complete system is in th trunk (built away very nicely). So the speaker/audiowires from the HU go to the factory AMP, and from there to the speakers.
    At this moment i have an AMP that is connected with a LowLevel Converter to one of the speakers in the back.
    Is it possible to use one of the speaker/audio wires BEFORE it`s amplified instead of using a LowLevel Converter. At this moment when there is music playing with a rather high BPM the bass doesn`t sound synchronic with the bass from the other speakers.
    I have drawn a nice little sketch from the situation.
    If you`re not first, you`re last !
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Sure you could slap some RCA ends on the wires and connect directly into the amp without a LOC. However, some Bose systems are balanced I believe and there are a few ways around that. You could use one signal wire and the vehicle ground for each RCA end. Or you can find yourself some cheap balanced converters.
    That is another issue entirely.
    Your sub is a much larger speaker and it will not react as fast as smaller speakers. Also, it could be a problem of the sub box not controlling the sub properly. Or, the time difference it takes for the lower frequencies to reach your ears is longer than what it takes from the other speakers. This can be corrected with tuning called "time alignment" or "time delay". Delay your other speakers slightly and the sub will blend better. Just some tips.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    IIRC www.pacaudio.com and paripheral electronics make bose interfaces that do exactly what you are trying to do
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Sep 2006
    close scott...
    www.pac-audio.com
    also...
    www.soundgate.com
    www.blitzsafe.com
    www.peripheralelectronics.com
    to name a few others..but then again these are LOC basically. Some BOSE sytems you can get away without them. It really depends on the car.
    Newbie Postman's Avatar
    Mar 2006
    Sacramento
    I know on late model Audi's it's already a low level signal going into the Bose amp, and I believe Acura's are the same, couldn't say on an Opel but it's worth a try. Remember if you do it like you're sketch and you do have low level preamp, you just halfed your voltage to the rear channels. Personally I would ditch the rear and run the sub and front stage to see how it sounds (assuming you do have the low level)
    In regards to the sub, have you tried reversing the phase of the sub. You may be surprised how that can improve the sound.
    Mar 2006
    Sacramento
    Quote Originally Posted by durwood View Post
    close scott...
    www.pac-audio.com
    Much better, I was going to say they need to get a more professional site!
    Dec 2004
    Los Angeles Ca
    lol
    sorry about that
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Feb 2006
    Holland
    Awesome, thanx for all teh reply`s. I will try asap.
    Also all the Bose equipemnt from PAC is for much newer cars for as far as ii could see. The Bose system in my car is nice because it`s integrated, but the expandability sux big time. I now use an FM Modulator (wired one) to get my audio from my CarPC to my HU but that`s also not a clear sound option. The other option i have is hacking in the CD Changer cable and hijack the audio wires. But then i always have the CD on my display with the tracks playing (which can`t be heared then).
    Dec 2004
    Los Angeles Ca
    i did the cdchanger hack for a while when i had my ipod and no computer. it works great. i'd go that route if you're not willing to drop the whole bose system
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Feb 2006
    Holland
    I think i will try that instead of the FM Modulator. Only i wish i could pause the cd changer or show a generic message on my display like " CD " or something. But i think that`s never gonna happen
  1. Newb question about amp and sub
    By jon2341 in forum Car Audio
    Last Post: 10-29-2006, 10:03 AM
  2. Noob amp question
    By cjnewbs in forum Newbie
    Last Post: 05-13-2006, 10:24 AM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Those with a hu, amp, and carpc
    By falconey in forum Car Audio
    Last Post: 09-14-2004, 08:27 AM
  5. Replies: 1
    Last Post: 09-06-2004, 01:52 AM
