Results 1 to 5 of 5
Thread: ohms question
    Jan 2007
    ohms question
    My setup is the following:
    Audio
    -Infinity 7541a Reference Series 111w RMS 4 Channel at 4ohms
    -Infinity Kappa Perfect6.1 Components 100wRMS 4ohms
    -Infinity Kappa 6x9mids 110w RMS 2ohms
    Will running the mids at 2ohms and components at 4ohms be a problem?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    shouldn't be, it'll just draw your soundstage back behind your head (most likely) and also will be a dirtier signal back there too
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jan 2007
    yeah, the 2ohm speakers will be in the rear. How much worse do you think the sound quality will really be? My main concern is that i dont cause any damage to the speakers running a different ohm than the amp is set to. Thanks!
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    There's no "set to". the 111W 4ohms means when you connect a 4 ohm load on it, the amp can only send out a max of 111W safely. If you look at the specs on that amp, it also says 139W 2ohms, which means 139 watts if you connect a 2 ohm load on it. Since they will be on different channels, it's okay to mix the impedances, you'll just have different amplification levels on the different channels.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Jan 2007
    oh now i understand, thank you for clearing that up.
    I havent inspected my closely yet and was under the impression that it had a switch to choose between 2ohms and 4ohms. a noob misunderstanding i will admit. Thank you.
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Paint And Polish Question
    By gboy in forum Fabrication
    Last Post: 08-13-2005, 08:22 PM
  3. Ohms, Watts, speakers & AMPs - confused
    By kingtut in forum Car Audio
    Last Post: 07-15-2005, 06:40 AM
  4. speaker connection question
    By modh1984 in forum Car Audio
    Last Post: 05-24-2005, 01:27 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
