Results 1 to 10 of 13
Thread: humming
    Dec 2006
    humming
    im running M2 ATX/jetways F4/sony amp.
    when i turn the pc on half way through the boot screen when it says windows is starting.... this slight humming can be herd, i think it coinsides with when windows starts its sound device.
    how can i stop this?
    i notice theres a 0.05v difference between negetive on both sides of the M2 ATX, so the mother board and the amp have slightly different megetives, could this be the prob?? would it fry anything if i grounded negetive out on the PSU and on the car?
    cheers
    Ralph
    _
    Mar 2004
    Little Elm, Texas
    have you matched your gains on your amps?
    Jan Bennett
    Dec 2006
    Quote Originally Posted by RedGTiVR6 View Post
    erm, not sure what you mean, i turn the gain up so it sounds bout right, this hum is when it should be silent, so what the opc thinks is silent the amp thinks is a hum...
    Ralph
    Feb 2007
    Quote Originally Posted by Ralphh85 View Post
    Ralph
    do you have any audio lines running in tandem with power lines? Power curent causes feedback...AC current usually causes a pulsing sound out of the speakers....but a DC curent will produce a level hum.
    _
    Mar 2004
    Little Elm, Texas
    Ralph
    http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning
    Please tune your amps properly first.
    Jan Bennett
    Newbie supraman22's Avatar
    Feb 2007
    I had this problem with my audio too. Come to find out it was bad pre outs on the cd player. id check that out, it could either be that or like a few have said make sure your audio wires are on a different side of the car as your power wires. You can get nasty engine noise if you cross them.
    Mar 2007
    sand the paint
    if you sand the paint of a spot on the car completly and then ground the wire back you should loose all extra ground noise
    cheers
    Ralph
    Mar 2007
    sand all the paint off the spot where your ground is. and if that doe=nt work. tru=y using a different spot or a bigger ground wire.
    _
    Mar 2004
    Little Elm, Texas
    88 - why the double posts?
    and sanding down the paint won't always solve the problem.
    Jan Bennett
    Dec 2006
    i have never ever had this problem before and have had many different set ups in different cars.
    the negetive of the amp and psu input are both soldered to the main 16mm2 cable which runs from battery in boot to the engine int he front. so a very good earth connection.
    also the amp is right next to the pc, with only a 1m jack to phono cable connecting them so should be good connection there to?!
    cheers to thoes trying to help
    Ralph
  1. DC-AC Inverter
    By badinstincts in forum Power Supplies
    Last Post: 01-22-2007, 11:08 AM
  2. very strange speaker problem
    By saddlebacks in forum Car Audio
    Last Post: 01-02-2006, 06:36 AM
  3. need help with hisssing and humming noise
    By pimpmode in forum PowerVoice
    Last Post: 05-31-2005, 04:37 AM
  4. Inverter with Toughbook - humming problem solved
    By petemillis in forum Power Supplies
    Last Post: 11-02-2004, 02:12 PM
  5. humming sounds coming from setup?! should i worry?
    By BigGuns in forum Power Supplies
    Last Post: 04-13-2004, 02:00 PM
