We're not of the spoon feeding kind here.
hi all newbie here, im here to ask for your help on fitting a sub, i currently have two parsell shelf speakers running of a 500 watt amp, off my car battery, but i also want to use another amp to run a sub i've recently purchased, so i will have to amps both running off the car battery(is this ok?) and i would also like to know, can i use a 2 ohm amp with a 4 ohm sub? and 1 last thing how powerfull amp should i be looking to buy if i have got a 1200 watt sub?
thanks in advance
aaron
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
You need to run 2 4ohm subs in parallel if your gonna use a 2 ohm amp. And if your using a 1200 watt sub, then a amp with similar wattage.
a 2 ohm amp just means that it's stable down to 2 ohm's, but it can run a 4 ohm or even an 8 ohm load...
it will probably make it's most power at the 2 ohm's, but also run it's hottest & will be a bit more distorted...
also, if you have a 1200 wrms sub (rms being the key word here) then you want to find an amp as close to (or above) 1200 wrms @ 2ohms as possible
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
If you're going to power a 1200 watt amp in adition to the 500 watt you already have you'll NEED to invest in a deep cell battery and significantly beefier alternator. 1700 watts in addition to what you already have in your system roughly translates to 120 amps....most car alternators don't push more than 90-105 amps.
like he said^^^^
yeah, a real 1,700 watts rms is no joke & will take some serious power additions for sure.... chances are if your using cheaper components that "1,700 watt system" is really no wear near half that though....
thanks for the help guys, im only using a cheap amp, so would my alternator be able to handle the power?
what are your amp's fuses rated at? what amperage does your alt. put out?
M10k
My Car Pc Install
My Boat Pc worklog
