Results 1 to 7 of 7
Thread: 04 Grand prix radio stopped working
    Feb 2007
    Hello, does anyone know the location of the stock amplifier on an 04 Grand Prix GT? My radio stopped working one day & I have checked the 2 radio fuses that I can find. Is ther an additional fuse for the "door chime module" or the on-board amp?
    The display works and the radio collects & displays the station/song info data, but there is no audio coming out. Please help, I'm going on 5 months without tunes!
    Thnks
    Mistakang
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by mistakang View Post
    Thnks
    Mistakang
    Mp3car.com == CarPC
    Might want to go to a forum specific to your car. You might find some answers but not as quickly as you would elsewhere.
    And if it is an "onboard" amp meaning in the HU itself, then the fuse on the back of it is the one.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Thnks
    Mistakang
    stock amplifier eh? If you've got a premium sound system in the car then there would be a small amplifier inside your consol somewhere...probably in the general direction of below and to the back from your stereo. The fuse for that kind of amplifier is the same as one of the two fuse you already checked so in that regard, you're S.O.L.
    OEM HU's are a pain in the ***...there's no real good way to fix stuff that goes wrong with them. Because they're mass produced only slightly slower than bunnies you end up getting a few bad eggs. They also opporate at lower power ouputs so when they start to wear out they shut off pretty quick. I'm guessing your deck is probably on it's last leg...
    Oct 2006
    Your stock amp. is located in the truck between the speakers
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    i would just throw the stock HU away and install a TS and PC... Problem solved
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Quote Originally Posted by david69leonard View Post
    Not me I'd hit it with a hammer while it is still in the car cause that would just freak the out of anybody watching plus since there isnt a p.c. in there you would have a reason to put one in.
    Aron
    Absolutely 100% stock
    Constant Bitrate MrJamieR's Avatar
    Jan 2007
    Melbourne, VIC
    Carputer Haiku (thanks Ian Hughes)
    Serious error.
    All shortcuts have disappeared.
    Screen. Mind. Both are blank.
  1. CIMR-100 stopped working??
    By unrealer33 in forum General Hardware Discussion
    Last Post: 07-01-2003, 06:10 PM
  2. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 11:52 AM
  3. Help!! My Dennis K setup has stopped working
    By Glyn in forum LCD/Display
    Last Post: 08-30-2002, 04:20 PM
  4. it just stopped working.
    By cruzc_99 in forum General Hardware Discussion
    Last Post: 02-05-2002, 10:48 AM
  5. COM port stopped working... need help!
    By chris in forum General Hardware Discussion
    Last Post: 02-17-2001, 12:39 AM
