Results 1 to 7 of 7
Thread: Quick question about wiring
    Nov 2006
    I'm using a 4AWG cable from the battery to a distribution block. Coming off the block is:
    Rockford Fosgate P6001bd = 300W x 1 @ 4-Ohms RMS
    600W x 1 @ 2-Ohms RMS
    Rockford Fosgate P4004 = 50 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms). 200 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
    And my CarPC (using M2-ATX)
    The 4AWG cable has a fuse about 1 foot from the battery, and it goes to a 4 point distribution block which will power all three devices above. what size fuse should I use here? I'm using the 4AWG cable that came with this (High current MAXI fuse holder w/ 60 amp fuse): http://cgi.ebay.com/ws/eBayISAPI.dll...9659&rd=1&rd=1
    Does anyone have a link to where I can buy these fuses?
    Mar 2007
    id use a 60 for the fuse..go to autozone and u can buy a connector to go in the power wire that holds the fuse.. if anything blows it will just blow the fuse and nothing else
    _
    Mar 2004
    Little Elm, Texas
    any parts store will have the fuse.
    thread moved to car audio.
    Jan Bennett
    Nov 2006
    ok cool, it has a 50amp fuse with it...
    Also, is it recomended to run a cable from the negative terminal of the batter to the trunk or should i just find ground back there?
    _
    Mar 2004
    Little Elm, Texas
    Find a solid grounding point in the trunk.
    Clean away all paint, and make sure you have a solid connection. Keep your ground as short as possible.
    Jan Bennett
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    On the ground part, You can run it to the back and distribute it to all your equipment or just find a clean spot back there.
    Also on the fuse part. I know I should post a new thread but anyway
    I use 4 channels amp Eclipse EA3422 that has 2x30A fuse. What fuse size do I use at the distro block? 30A or 60A? As of now, I have 30A on the distro.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    you should use a 60A at the distro. Most fuses will not blow until they see about double what they are rated for a few seconds.
  1. Opus Wiring Diagram Question?
    By rdiggidy in forum Newbie
    Last Post: 12-26-2005, 12:39 AM
  2. Newbie Inverter Wiring Question
    By arebelspy in forum Power Supplies
    Last Post: 10-06-2005, 03:26 PM
  3. quick cinergy question
    By bacardi in forum Road Runner
    Last Post: 09-27-2005, 07:18 PM
  4. Headless Setup - Quick Amp Wiring Question.
    By crosseye in forum Car Audio
    Last Post: 07-13-2004, 03:18 PM
  5. Starvision LCD.....quick question.
    By Seabass in forum General Hardware Discussion
    Last Post: 05-27-2004, 07:38 PM
