Results 1 to 9 of 9
Thread: Am i missing anything in this diagram?
    Nov 2006
    Here is what I came up with so far...I'm going to get started on this in the next day or so...Thoughts? its a rookie diagram for sure
    The sound card is the Live! 24bit external, which is powered from USB, no need to go external power for that.
    Oct 2006
    Looks good except I don't know why you are putting your touchscreen on a switched power source. Unless your touchscreen doesn't have a power button or you won't have access to it after you install it, there is no reason to switch that power source. Also the cigarette lighter should already be fused.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    i would throw in a power cap for ur amps... other than that looks good to me!
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by spoonraker View Post
    I'd put it on a switched source. It's a nuisance to always have to turn your screen on. Why not let your car do it. Set your screen to auto on and when the ignition turns on, screen turns on. I would recommend another method too, but its more complex and you are fine.
    I wouldn't worry about CAPs at the moment. They are one of those additions for when you have money burning a hole in your pocket and you don;t knwo what to do with it. Better to opt for a Big 3 upgrade instead.
    Kudos for doing a diagram. it will help you keep thigns organized.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    exactly the first two replies are steering you wrong
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    I agree. In my old car I had my screen running off a switched output of the OPUS unit. My screen doesn't have auto on but when the computer turns off I know that screen will go off also. I've accidently left the screen on before. One day you'll be in a rush and forget to turn it off.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Nov 2006
    one question though, should I have a switch up by the driver seat to turn the carPC on/off also? What if i want to drive the car around but have the carpc off?
    Dec 2004
    Los Angeles Ca
    that's totally up to you. it could be handy for a reboot, but it's not needed.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by nkotch View Post
    I agree, If you power your screen off of your power supply, given that you get the right PSU then you'll have a regulated power source giving you cleaner power to the screen
    And a switch for main power for your computer may not be a bad idea, given you need to shutdown the pc after it froze. But when using switches, it may be best to use a relay, depending on the amount of current running through the wires.
    PROGRESS:
  1. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 07:19 PM
  2. missing lilliput cables
    By dstryr99 in forum LCD/Display
    Last Post: 09-25-2006, 07:10 PM
  3. CarPC wiring diagram
    By Tommy in forum General MP3Car Discussion
    Last Post: 08-14-2005, 08:03 PM
  4. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 11:10 PM
  5. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
