Results 1 to 6 of 6
Thread: speaker RMS question
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    i have got 2 of MBQaurt discus with power handling between 30-70watt
    i would like to put them to use, i have found a small radioshack amplifier on ebay which is rated @ 40 watt @ 4 ohm.
    question?
    if you have to of those speakers. obviously i will have to connect them as an 8 ohm, but the the RMS would be reduced from 40 x 1 to as 20 x 2 , would this small amplifier power those 2 speakers, i am not looking for loud, but rather a small stereo build up
    Yev
    R. T. F. M
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Is it 40Wx2? or 40Wx1?
    If its 40WX1 and you are going to wire them in series, then it will reduce power output to 20x1 and then dived that by 2 again so each speaker would see 10W.
    Oct 2006
    is your amp rated at anything other than 4ohm? With a 2 ohm load they would be each seeing 40W.
    Nov 2005
    Chicago
    the amp can be @ 4, 8, 16 ohms
    so if i am hooking up 4 ohm speakers, i will need to use 8 ohm plug
    this is a link for amplifier
    http://www.radioshack.com/product/in...&tab=techSpecs
    this is a link for speakers
    http://www.mbquart.com/en/produkte/c...php?nr=rua_210
    Yev
    R. T. F. M
    _
    Mar 2004
    Little Elm, Texas
    That's a PA amplifier.
    Look for 'car audio' amplifiers. They run on 12v and have the proper outputs for speakers.
    Jan Bennett
    Nov 2005
    Chicago
    thanks Jan
    Yev
    R. T. F. M
  1. Quick question about wiring
    By Kurack in forum Car Audio
    Last Post: 03-01-2007, 01:04 PM
  2. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  3. ****PIC ! CDT CL-61 6.5" New Car Speaker Comp !PIC ****
    By neema12 in forum Classified Archive
    Last Post: 12-19-2004, 06:44 PM
  4. Replies: 11
    Last Post: 09-02-2004, 04:11 PM
  5. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
