Results 1 to 10 of 15
Thread: parallel series help?
    Newbie ali7up's Avatar
    Feb 2007
    Georgia
    i am trying to wire my 4 ohm speakers into a 2 channel amp in parallel series, the speakers run at 100w rms and my amp runs at 100w at 2 ohm, when i am wiring the amps, there are connections for each channel so it goes like this + - + -, when i am wiring do i just use 1(+ -) connection or do i connect the + into one and the - into the other
    thanks
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    you can't run your 4 Ohm speakers @ 2 Ohm, unless you use 2 speakers per channel, which will request a 200watt load. And since your amp is only 100watts @ 2Ohm, you're underpowering your speakers.
    speakers in series
    speakers in parallel
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Quote Originally Posted by IC-C30 View Post
    Just adding more to what was already said. The problem with underpowering subs could cause a blown sub from distortion. What kind of amp and subs are you running. This information will help us guide you in a direction.
    Aron
    Absolutely 100% stock
    Feb 2007
    Georgia
    hmmm... is there any other way to run the speakers with the amp, the amp is
    50 x 2 at 4 ohm
    100 x 2 at 2 ohm
    200 x 1 4 ohm bridged
    the speakers are 100w rms and 350 w max imp: 4 ohm
    Jun 2006
    Abele, Belgium
    I think the OP meant just regular speakers like compo's or coaxials.... But other than that.... Yeah, what speakers and amp are you planning to use.
    edit: yeah, you can use the amp if you buy 50watt, 4Ohm speakers, or 100watt, 2 Ohm speakers, or buy a second amp just like it and use 1 amp per speaker and bridge the 2 channels. BUT you're gonna have a hard time setting up both amps equal.
    CLARION HX-D2
    Feb 2007
    Georgia
    well thanks for the help i think i am just gonna sell this amp and get one that puts out 100w x 2 at 4 ohm
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by ali7up View Post
    As long as you stay away from fleamarket brands, cause they will never get their rated output! And one other thing: It's better to overpower a little bit (say an amp with 110watt or so per channel) than to underpower. It will give you more headroom and give just a little more punch to your sound.
    CLARION HX-D2
    Feb 2007
    Georgia
    yea i learned that the hard way now i am staying away from anything fleamarket, so between 100 and 110w rms, alrigth
    Jun 2006
    Abele, Belgium
    I don't know what your budget is, but this is a nice one:
    http://www.steg-america.com/models/k_series/k201.htm
    Don't know what it costs in the US though. But in europe you're paying €375 for it ($500)
    CLARION HX-D2
    Feb 2007
    Georgia
    whats the highest i can go without over doing the speaker, i have only seen 100 or 125w not so many 105, 110, etc.
    edit. my budget i am not trying to spend anything more than $150 per amp
  1. Parallel port relay control in RR using Autoit?
    By momanz in forum Road Runner
    Last Post: 04-03-2009, 10:20 AM
  2. Ohms, Watts, speakers & AMPs - confused
    By kingtut in forum Car Audio
    Last Post: 07-15-2005, 06:40 AM
  3. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  4. parallel port LCD problem
    By jethari in forum LCD/Display
    Last Post: 09-05-2004, 10:56 PM
  5. Crystal Fontz parallel LCD
    By CaffeineAddict in forum LCD/Display
    Last Post: 09-27-2001, 02:55 PM
