ok i have found a 2000w amp with is 2 x 400RMS 4 oms
boss tho that good ?
Rule of thumb is you go slightly larger than the speaker max so prob round 400 rms but you wanna make sure of it , take it to a well recommended dealer and ask them, if they say "they will cut you a deal on this real good amp goes hard etc etc " go elsewhere. they can also get it right on because your continious power is different from your RMS power
Wassup Manus
i thort BOSs was named make i allways thort boss whay a good make
What about this
http://cgi.ebay.co.uk/4x-400W-MOSFET...QQcmdZViewItem
look little to cheap
Or even thisd look a lot better
JBL GTO601.1 580 WATT MONO AMPLIFIER
http://cgi.ebay.co.uk/JBL-GTO601-1-5...QQcmdZViewItem
Please help me im a noob at this
Please
being a noob has nothing to do with it. you want slightly more rms. walk yourself into a audio store, best buy for instance, they will most certainly point you in the right direction. you arent really taking any of our advice.
audio stores/web sites > ebay
EDIT: if your bridging it you need to be looking for the 2 ohm, if you have a 2 ohm sub atleast. At 2 ohm you get more power. for example, 400 rms @ 4 ohm --- 600 rms @ 2 ohm
Rockford Fosgate 5002 (subs)
(2) 12" Infinity REF1252
(2) Pioneer TS-A1681R 6.5
(2) Pioneer TS-A4670R 4X6
(2) Polk Audio 2" Tweeters
most amps in the pricerange you're looking at wont be stable at 2 ohms when bridged.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
I have the previous version sub with the red tornado cone with a 2200 wat 2-channel amp running to it. Also I have the subs one per channel so I am pushing about 500 watts to each and they sound great. They are inside a 1.85 ft3 box for each sub. Sometimes with a hard hit I get scared they they might separate, but I use the heck out of them and they have not yet blown.
My sub is 380 4 OMSEDIT: if your bridging it you need to be looking for the 2 ohm, if you have a 2 ohm sub atleast. At 2 ohm you get more power. for example, 400 rms @ 4 ohm --- 600 rms @ 2 ohm
What does the OMS mean
thanks
